Omega B22 enlarger
Discussion in 'The Darkroom' started by theinvisiblecity, Feb 19, 2006.
  1. theinvisiblecity
    theinvisiblecity TPF Noob!
    Mar 25, 2005
    29
    Cleveland, OH
    ...got one from my neighbor...bulb is burned out but a new one is on the way.....anyone know anything about it?.....it looks like it probably can't make prints much larger than 11x14's but I can't tell until I get it turned on......
    ..worth messing with or should I still be on the lookout?
  2. Torus34
    Torus34 No longer a newbie, moving up!
    Jan 26, 2006
    2,117
    37
    Tottenville, Staten Island, NYC USA
    The Omegas were well built. I use a Cromega C for printing B&W 35mm & 6x6cm. The 22's were considered to be very good enlargers when they were still being manufactured. I had the honor of meeting Mr. Simmons, the designer of the Omega line.
  3. KevinR
    KevinR TPF Noob!
    Feb 1, 2005
    1,204
    4
    Dearborn, MI
    It's a nice enlarger. You can get the column for the B-22XL if you want to make bigger prints. What kind of lens is with it? Because that will be a quality issue if your worried about it.
  4. theinvisiblecity
    Mar 25, 2005
    29
    Cleveland, OH
    right now it's a 50mm rodenstock omegar lens....needs a good cleaning but should be decent?....perhaps it would be wise to invest in something really nice? - seeing is how the enlarger was free...I also have a 50mm Beslar (yes Beslar, not bessler) and a 75mm Omergeron....I have no clue as to the quality of these lenses as I've always just used the Nikons on the enlargers at the school and never gave it another thought...perhaps someone can shed some light on what I have?
  5. theinvisiblecity
    Mar 25, 2005
    29
    Cleveland, OH
    oh yea and I got the new bulb....it looks like it's make up to 16x20's as is....not bad..not bad....
    ...I assume the XL column is just a taller version of what I have?
  6. KevinR
    KevinR TPF Noob!
    Feb 1, 2005
    1,204
    4
    Dearborn, MI
    That's right
    The omegar is a 3 element design. This is Rodenstocks cheapest line. On the other hand, I have one and it works really nice.
    The Omegaron is a 4 element coated design. This is a pretty nice lens.
    The beslar is a pretty cheap one. Try it out, but I would think you would end up using the others.
  7. terri
    terri Administrator Staff Member Supporting Member
    Sep 2, 2003
    27,356
    2,831
    In the mental ward of this forum
    Congrats on getting the enlarger! :thumbup:
    The best way to decide about lenses is to just start printing, and try them all. Do you have a reasonably good grain focuser? Use that, and if you're convinced you are well focused, but you believe your prints are soft, you might want to look around for higher quality.
    Sometimes simply stopping down a lens will give you better results (say, the images are soft at f.8 but noticably sharper at f.16). This might make for longer exposure times, but it's a workaround if you want to use what you have to save $$ while learning. Good luck with it! :)
omega b 22 pdf
omega b22
omega b22 enlarger
omega b22 enlarger manual butkus
omega b22 enlarger review
omega enlarger b22
omega enlarger b22 review
simmon omega enlarger b-22
