- Joined
- May 1, 2008
- Messages
- 25,418
- Reaction score
- 4,999
- Location
- UK - England
- Website
- www.deviantart.com
- Can others edit my Photos
- Photos OK to edit
Thanks for all the responses. My head is kinda spinning with everything I've been reading lol. I would say I'll stick to my current camera, and just buy some good EF glass so I have it if I go FF, but I can't get past the slow FPS and low ISO.
Sounds like a good plan and in motor sports chances are you won't be too limited by cutting out EF-S lenses.
I'm not 100% sure on USA prices, but if I were you I'd have a serious look at the 70-200mm f2.8 lens ranges on offer (ideally if you can afford it the IS MII is the best their is for Canon). You might also consider the Sigma 120-300mm f2.8 OS Sport, its more expensive (I've a feeling it might be at the upper limit for your budget), but it gives you a touch more reach. Have a look at the shots you've gotten and see if you make much use of the 70-120mm ish range. You will want to get a monopod with that lens, it is heavier and will fatigue you quicker (70-200mm f2.8 are typically quite easy to adapt to hand holding for long periods of time).
Otherwise its really a case of sitting down and working out what you really want and need from a new lens(es).
