Otter Photoshop!
Discussion in 'Graphics Programs and Photo Gallery' started by Overread, Jan 3, 2009.
  1. Overread
    May 1, 2008
    24,006
    4,152
    UK - England
    Well sometimes editing is easy and other times I just feel really lost in it all - and lost is what I am now. Edited this shot twice now to two slightly different effects and really can't tell which I prefer:
    a
    [​IMG]
    http://farm4.static.flickr.com/3484/3230017136_c6a9010cff_o.jpg
    b
    [​IMG]
    http://farm4.static.flickr.com/3338/3230017142_0845cd7e19_o.jpg
    So anyone got some input on these two edits? Ideas as to which is the better and any modifications people might try would be appreciated
  2. OldClicker
    OldClicker TPF Noob!
    Nov 29, 2008
    194
    Mundelein, IL USA
    They look the same to me. - TF
  3. Overread
    May 1, 2008
    24,006
    4,152
    UK - England
    unfortunatly the difference is minor - if you save them to your computer and flick between the two images its easier to see the differnce - online like this they do look too similar to tell apart
  4. Ls3D
    Ls3D TPF Noob!
    Dec 15, 2007
    1,279
    Encinitas Cali
    LOOKS LI, whoops that always happens when I come back from photoshop - some will know why. So it looks like your used some shadow/highlight and sharpening.. maybe oversaturated it a bit after a few curves?
    I wonder if a slightly larger aperture would have diffused the somewhat distracting (interesting) reflection...
    Here is a different take on the saturation, levels, and with a blend of layers ultimately brushed together in a minute or so. -S
    [​IMG]
  5. Overread
    May 1, 2008
    24,006
    4,152
    UK - England
    I rather like that edit - looks like you added more saturation into the ground and otter area whilst leaving the reflection untouched. Chances are a wider aperture might have lost the reflection though I think it would still have been there to a greater or lesser extent.
    For the original I applied a single contrast mask (essentailly shadows and highlights) and then the second I applied another conrast mask which was set to affect the foreground and only affect the water a tiny bit (50% ish with a layer brush)
  6. Ls3D
    Ls3D TPF Noob!
    Dec 15, 2007
    1,279
    Encinitas Cali
    Actually I ran the typical S curve with a slight bias towards the bottom (darks), then desaturated until my eye said stop, that is grass. Then I used an oval patch of your plan B and turned that layer down a touch to blend into my take on the levels.
    I think more bokeh would be nice on that reflection and give the subject more weight, but I sure can't pull past 200mm f/2.8... Oh I see you have an 1.4x on there..
    -Shea
  7. Overread
    May 1, 2008
    24,006
    4,152
    UK - England
    I think you have gone way past what I understand about curves in that. S curve I can make a guess at but the other part you have lost me a bit.
    And yes a 1.4TC is on the lens - for wildlife in zoos and such I find that the extra 1.4 to focal length does help and f4 is not a bad max aperture (especailly on such a bright day!)
  8. Peano
    Peano TPF Noob!
    Dec 21, 2008
    358
    22
    Washington, DC
    What did you start with? Can you post the unretouched version?
  9. Overread
    May 1, 2008
    24,006
    4,152
    UK - England
    The shot is RAW so its tricky to post an untouched version online *unlit photobucket accept raws ;)* I can post a version with no edits save my RAW processing though - of course any error in my RAW processing will still be present
  10. Peano
    Peano TPF Noob!
    Dec 21, 2008
    358
    22
    Washington, DC
    If you want others to play with the raw file, you can upload it to Yousendit and post the link here.
