outdoor music festivals
rangerfn
im photographing a band at summerfest on sunday at 5:30pm. i have a canon ef50mmf1.8,standard 18-55, and a 75-300 lens. which should i use. its supposed to be a nice sunny day so there will probably little stage lighting used at that time. i use the 50mm for indoor club shots. please help!
You're not limited by lighting, so it entirely depends on where you can stand. If you can get close enough to the band the 18-55 is the way to go. Take the other two along with you incase you need to change your mind.
thanx garbz, i'll try that one first
