Outdoor Potrait Photography + right exposure
Discussion in 'Photography Beginners' Forum' started by darshan_nabar, Jun 11, 2009.
  1. darshan_nabar
    darshan_nabar TPF Noob!
    Jun 11, 2009
    Netherlands
    Hello Guys,
    When I take a photograph in the outdoor by reducing the aperture I get a good color saturation of the sky and the exposure is right. However when I shoot somebody in the same background the subject turns dark. When I increase the aperture, the background is washed out but the subject is bright. I tried using a flash to brighten the subject but that helps only when the subject is very close. Can somebody help me how to take bright pictures without washing the background?
    regards,
    Darshan
  2. Ptyler22
    Ptyler22 TPF Noob!
    May 23, 2008
    789
    Massachusetts
    Well you could use a polarizer, this will deepen the blues in the sky and cut glare, or just keep playing around with the flash, and you should be able to make it work
  3. farmerj
    farmerj TPF Noob!
    Apr 26, 2009
    588
    Graduated Neutral filter, Polarizer to a degree or fill flash.
  4. Samanax
    Samanax TPF Noob!
    Jan 1, 2009
    2,562
    Kaneohe, Oahu
    Got any sample pictures?
  5. NateS
    NateS TPF Noob!
    Sep 27, 2007
    2,753
    40
    Missouri
    Graduated ND would be kind of silly for any shots where the person was in the whole frame. I don't think you'd want their top half darker than their bottom half.
    You are on the right idea with flash. What flash are you using? I have an SB-600 and Stofen Diffuser. It works great for shaded shots to light the subject while I expose for the background. I usually also have to throw on a ND (not grad ND) to block some light so that I can shoot around f/2.8-f/4 outdoors with my crappy 1/200th max sync speed. I use a 3 stop ND filter.
  6. JerryPH
    Oct 14, 2007
    6,111
    15
    Montreal, QC, Canada
    Basically... underexpose the daylight settings in camera and overpower the sun with off camera flash.
    No ND filters, just proper use of off camera flash, a touch of sharpening and a little vignette added:
    [​IMG]
  7. itznfb
    itznfb TPF Noob!
    May 21, 2008
    1,167
    Pittsburgh, PA
    get a bigger flash
  8. Chairman7w
    Chairman7w TPF Noob!
    Jan 21, 2009
    301
    Sacramento, CA
    That is the classic dilemma of shooting in bright sunlight. Fill flash is definitely the way to go. This was taken in the middle of the day (note the shadows) and before I turned on the flash it was basically just silouettes. It's not perfect by any means, but you can see their faces now.
    [​IMG]
  9. farmerj
    farmerj TPF Noob!
    Apr 26, 2009
    588
    There's no "right" way to do something like this.
    Several techniques work. Some work easier than others. If you have a flash, fill flash works, if you have a ND filter, that will work. It would be interesting to see how a polarizing filter would work to do this.
    Learn several techniques, put em all in the bag, and use what comes easiest to you.
  10. itznfb
    itznfb TPF Noob!
    May 21, 2008
    1,167
    Pittsburgh, PA
    how would a ND filter work, don't ND filters reduce incoming light evenly, so the subject would still be overshadowed by the bright light?
  11. farmerj
    farmerj TPF Noob!
    Apr 26, 2009
    588
    You wear sunglasses? Same thing there. All a ND filter is, is a sunglassed for your camera.
  12. itznfb
    itznfb TPF Noob!
    May 21, 2008
    1,167
    Pittsburgh, PA
    makes sense. i've never used one... seems useful though.
3 stop nd filter
lck'l
outdoor potrait
right exposure of outdoor
right exposure on subject or background
the right exposure for outside portrait
what is the right exposure for outdoor
what is the right exposure for outside
