Over-development?
Discussion in 'The Darkroom' started by julius, Jun 12, 2006.
  1. julius
    julius TPF Noob!
    May 18, 2006
    133
    So i just developed a roll of Delta 100. It looks fine at a glance, but on closer inspection or under enlargement it can be seen that there is a large dark cloud through the middle of the roll. The sides of the film are look ok but it's just this large smudge straight down the centre that continues over the whole film.
    It's strange because I've developed a few rolls now and they've come out fine. This roll was developed with new batches of chemicals at recommended concentrations, temperatures and times. Does anyone know what I have done wrong?
    edit: I didn't use stop bath in between developing and fixing but I did rinse with plenty of water. Could this be it?
  2. Hertz van Rental
    Hertz van Rental We're supposed to post photos?
    Nov 8, 2004
    16,738
    46
    Where am I now?
    Any chance of a scan of a neg or a print?
    It's hard to be specific with a diagnosis without seeing the effects.
    I doubt very much that it is over-development.
    Sounds more like you've got a light leak somewhere. As you say it's along the whole length it's either in the camera or the processing tank.
  3. Philip Weir
    Philip Weir TPF Noob!
    Apr 29, 2006
    506
    Sydney, Australia. The land of peace and sunshine.
    Hi Julius,
    I think you've hit the nail on the head, if you didn't use a stop bath, which is acid and immediately stops the developement, then the developer could still be working on the centre of the film. As "Hertz van Rental" says, scan and post an example and then we can more easily comment. Philip.
    www.philipweirphotography.com
  4. JamesD
    JamesD Between darkrooms
    Mar 20, 2005
    1,025
    12
    Living in Snapshot reality.
    Just curious, what camera and lens are you using?
  5. julius
    julius TPF Noob!
    May 18, 2006
    133
    Canon A-1
    28mm
    Thanks for the comments, I would scan the negs but I don't have access to a scanner. I had been using water on my other negs and I didn't want to change anything because this was a particularily important roll:confused: . Ahh well, such is life.
  6. julius
    julius TPF Noob!
    May 18, 2006
    133
    I threw the film in fixer for 10 minutes and it fixed (haha) the problem
