- Joined
- May 1, 2008
- Messages
- 25,422
- Reaction score
- 5,001
- Location
- UK - England
- Website
- www.deviantart.com
- Can others edit my Photos
- Photos OK to edit
Oi behave you or I'll start finding even more spiders and creepy crawlies to scare you with!!!!
Manual, who needs it when ya got program? LOLOLOL You just use the Program setting. The camera does its best to set everything for you but then after you take the image you can look at it and make the adjustments needed to make it better or correct errors.
Thats right Master Photograffer!
Or is that cheating?
Also I read that when shooting in manual mode you should first try and set the ISO to the lowest setting possible with out causing or being in danger of camera shake and then adjust your aperture and shutter speed from there.
Does this make sense, does anyone practice this?
Rumdaddy may have had a little too much to drink , but...I think he is just pulling some legs with his original post. It certainly got a few peoples attention.
Oh hey... it's THIS thread. It looks a little different this time, but it's just this same ol' thread again. Nice to see you, thread!
You say shoot on Program, see the results, then switch to manual to fine tune it to fit your desired end result? I say, SURE. You are then of course taking quite a while to set up a shot you could have nailed from the get go, but if you want to see a "suggestion" offered by your camera in it's little creative mode, then why not.
When shooting in manual, YES most people will leave their ISO to the lowest setting feasible. As I understand it, you are saying that you should leave your ISO as low as possible, and then only to use it to compensate for the lighting conditions in adjusting your Shutter (and Aperture) to facilitate a setup that will minimize your effects of a hand held shot, in your picture. To this I say, YES.
I personally do not raise the ISO for s#its and giggles, I use it to allow flexibility with my other settings (shutter). If my light is low, I'm wide open, and my shutter speed is too slow; I will bump the ISO until it provides me with an acceptable shutter speed. I will balance the need for a fast shutter with the drawbacks of taking the ISO too high.
My understanding of your initial post.
