Panning head
Discussion in 'Photography Equipment & Products' started by Johnboy2978, Jan 20, 2008.
  1. Johnboy2978
    Johnboy2978 No longer a newbie, moving up!
    Oct 21, 2004
    1,797
    30
    Southwest Virginia
    So I have this bogen/manfrotto head (322RC2 Ball head):
    http://www.bhphotovideo.com/c/produ...rotto_322RC2_322RC2_Grip_Action_Ballhead.html
    and these legs (3021BPRO):
    http://www.bhphotovideo.com/c/produ...tto_3021BPRO_3021BPRO_Tripod_Legs_Black_.html
    And I would like to have a panning head for some panoramas. Can I get a head that would mount between the two, or do you have to switch them about?
    Someone in the past recommended this:
    http://www.feisol.com/english/feisolen.htm
    But I can't get much information about it. Would that work between the head and legs as a permanent mount, b/c I'm really not wanting to switch the heads around. I just want a panning head that will stay locked unless I need it for a panorama.
    Thanks
  2. table1349
    table1349 Been spending a lot of time on here!
    Sep 9, 2006
    Works perfectly. I use the setup and may be the one that recommended it in a previous post. I know that I have in one of the forums that I visit.
  3. Johnboy2978
    Oct 21, 2004
    1,797
    30
    Southwest Virginia
    So you can mount it between the legs and the 322RC2 head as a permanent mount using the panning head as needed?
    Did you get the PB70 or 90? And is there a difference other than wt?
  4. table1349
    Sep 9, 2006
    Yes It is there permantly, and I got the PB70. The 90 is larger than the 70. Mibht be something to consider if you would like an extra inch or so of height added to the head, or you are using MF equipment.
  5. Johnboy2978
    Oct 21, 2004
    1,797
    30
    Southwest Virginia
  6. table1349
    Sep 9, 2006
  7. Helen B
    Helen B TPF Noob!
    Sep 16, 2007
    3,296
    465
    Hell's Kitchen, New York
    Here's how I arrange things, from the top down:
    nodal slide, if necessary
    panoramic head
    ball head, for levelling pano head
    tripod
    Best,
    Helen
  8. table1349
    Sep 9, 2006
    Helen, what ball head are you using? Mine has a built in panning base. If I am wanting to do some true Pano shots I remove my 322 head altogether, attach the nodal slide to the panning head and level with the leveling head on my tripod legs.
    If I was using my ball head I would just add the nodal slide to the top and still level with the leveling head and skip the panning head altogether. One less thing to mess with, unless your ball head does not have the panning option. Just curious.
  9. Helen B
    Helen B TPF Noob!
    Sep 16, 2007
    3,296
    465
    That's effectively what I'm doing, except that the ball head is taking the place of the levelling head. I use a Burzynski ball head, which fixes straight in to the top of a Gitzo, replacing the centre column. The Burzynski is quite squat, and it has restricted angular movement so it is half way between a levelling bowl and a normal ball head. The key to both our systems is that the plane of rotation is level: there is a leveller between the top of the tripod and the pano plate. You wouldn't have that if you mounted a pano plate straight onto the 3021B Pro, would you?
    Best,
    Helen
  10. table1349
    Sep 9, 2006
    I am actually mounting the pano base onto the 3021 legs. I replaced the center column with the leveling center column. http://www.bhphotovideo.com/c/produ...nfrotto_555B_555B_Leveling_Center_Column.html
    put the pano base on the legs and the 322 head on the pano base. It raises the head a bit, but he 322 is a squat ball head being as it has the side grip on it instead of the standard ball head configuration.
    I checked out the Burzynski head. That is squat and massive isn't it. What Gitzo legs have you got that on? It looks pretty big from the photo in the article I found.
  11. Helen B
    Helen B TPF Noob!
    Sep 16, 2007
    3,296
    465
    I've got it on the GT3540 legs. It fits directly into the top of the legs.
    Best,
    Helen
feisol pb-70 review
pb-70 panning base
