Panorama fail
Discussion in 'Photoshop Challenges' started by Timppa, Oct 8, 2017.
  1. Timppa
    Timppa No longer a newbie, moving up!
    Dec 15, 2016
    191
    113
    Finland
    Hello!
    I am trying to make this nice panorama (from my visit to the Seychelles Islands), But the horizon just never seems to be good... There is cracks in it, and it is not a straight line....
    At one point, there is also an issue with the water, the stones are put nicely together, but the waterline is bad.
    What would be the best solution for me to fix this?
    If somebody wants to fix it for me, it is fine, but I would prefer to learn it myself, So if you do, tell me the steps you did.
    I can provide a link to a full size file if you want to give it a try (.dng). (or provide all the separate images I putted together (.nef)).
    [​IMG]
    Thanks!
  2. Timppa
    Dec 15, 2016
    191
    113
    Finland
    more zoomed in...
    [​IMG]
    (yes I used paint, because it is still so easy to just show something like that xD)
    I use mostly lightroom, and a bit of photoshop, I tried some warping to get the horizon straigt, or some clone tool... but either It is the wrong way, or I am bad at it...
  3. 480sparky
    480sparky Chief Free Electron Relocator Supporting Member
    Mar 8, 2011
    22,662
    8,119
    Iowa
    You'll need to Select (with Feathered Edges) those areas and edit them individually. Copy & paste the selection, then skew, rotate, move etc. as needed. Clone & Heal to tidy it up.
    To correct it, I would prefer the full-rez image.
  4. Timppa
    Dec 15, 2016
    191
    113
    Finland
    The biggest problem is also the general horizon, it is not straight, it is like a wave itself...
    I will send you the full-rez via messaging?
  5. 480sparky
    Mar 8, 2011
    22,662
    8,119
    Iowa
    Rotating the entire image is something any editing software should be able to do.
    You can't sent full-rez images via PMs. You'll need to provide links. I don't have any software I'm familiar with that uses dngs though.
  6. dennybeall
    dennybeall No longer a newbie, moving up!
    May 13, 2014
    2,105
    373
    Crystal River, Florida
    Here's a version with the horizon and the outside edge fixed. I forgot about the bit in the water...
    Just 15 minutes, with Photoshop 2017 on the laptop without getting out the Wacom.
    The key to dealing with straight lines for me is to use the rectangle Select tool and the clone brush.
  7. Timppa
    Dec 15, 2016
    191
    113
    Finland
    Wow,
    You really did a great job there!
    That's the way I was picturing it :).
    Would it be possible to send the .DNG (or .tiff?) file to me again so I can deal with the water.
    The outside edges I kept on on purpose, so there was more room for editing, I wasn't to sure if you would be warping or distorting or something like that xD. I always prefer to completely finish my panorama and then remove the outside white edges.
    It would have been nice to see your workflow, so I could improve mine. I really enjoy creating panorama's, but I never had a problem like this before. I'm guessing its the amount of objects in front that lines up nicely, and because of changing camera position the horizon line was always a 'tad' different in distance.
  8. dennybeall
    May 13, 2014
    2,105
    373
    You can help the software to do it's job if you mount the camera on a stable, LEVEL tripod and rotate carefully.
    I'm lazy so usually just hand hold with lots of overlap and fix it in post.
  9. Braineack
    Braineack Been spending a lot of time on here!
    Jun 17, 2013
    11,416
    4,426
    NoVA
    I use the free software ICE. (windows image composite editor -- something like that)
    it works great.
  10. ZombiesniperJr
    ZombiesniperJr Been spending a lot of time on here!
    Apr 16, 2016
    4,310
    1,934
    Angus Ontario
    can't help with the photo but nice shot.
  11. Timppa
    Dec 15, 2016
    191
    113
    Finland
    That is how I do it xD, I also do not like bringing tripods on holidays.
    I might check that out, thanks!
    Thank you !
    • Like Like x 1
  12. Braineack
    Jun 17, 2013
    11,416
    4,426
    NoVA
    I use it a lot for not just panoramas, but making my lens wider.
    example:
    [​IMG]
    DSC_2799_stitch
    by Braineack, on Flickr
    this was (4) images stitched together using ICE since shooting at 24mm wasn't wide enough to get everything in frame. My favorite part is the perspective controls it has, and can actually do cool stuff with video.
    I want to say this was 7 or 8 vertical images stitched: DSC02178_stitch
    example of the perspective controls: DSC02135_stitch
    other panos I've done with it: DSC03565_stitch DSC02334_stitch DSC_2953-1_stitch
