Good pan but I wish the left side was a little darker, not so hazy. I don't mind the mounts in the distance but the closer hills on that side don't look enough like the right side.
Good shot. How manys photos did you have to stitch?
i think it was 6 photos to stich... the shame of it is that you can't really see the castle that's there on the right side. i probably should have cropped out the post on the right too... or if i knew how to clone, i could just remove it and leave the mountains
What program did you use to stitch the pics together? You can tell where they are merged, and it appears to be 5 pics from the lines I count. Did you use aperature lock when you took these? That's the way a few of my panoramas came out when I didn't use the AE lock. You can use the smudge tool to eliminate some of the lines that are pretty visible if you use photoshop.
i didn't use AE lock (at least not intentionally, and apparently not at all) as i just found out how to use it when i got back from the trip... good call, i never thought about that before. AE lock for panoramics, check.
the stitch program is the one that came with the camera, canon stitch i think? are there better ones? i never really considered that before...
