Pentax *ist vs. Olympus?
Discussion in 'Photography Equipment & Products' started by prairiewindlady, Dec 20, 2007.
  1. prairiewindlady
    prairiewindlady TPF Noob!
    Oct 7, 2007
    31
    Burlington, NC
    I am rather new to the SLR world and I was wondering if any of you could give me some advice. I currently own a Pentax *ist DS (DSLR) and use a Promaster 28-300mm lens. I mainly take pictures of horses and I've found that while this particular camera/lens combination functions OK, I am still getting a lot of blurred images. (It isn't entirely the lens either, I also use a manual focus lens and the shots are still a bit fuzzy). I have been thinking about upgrading to an Olympus DSLR, as money is unfortunately an object and I've heard good things about the sharpness/clarity of Olympus DSLRs. I would be getting the Olympus E510...however I am still a little worried about the whole sharpness issue. I was wondering if anyone has any experience with the Olympus E510 and if it really does manage to get consistent clear shots of moving objects. In short, is the E510 really a step up and is it worth selling my Pentax for?
  2. Sideburns
    Sideburns TPF Noob!
    Aug 14, 2007
    2,796
    Windsor, Ontario
    you do not need to upgrade. You need to get a little more experience mostly. DSLRs are not just point and shoot. You can get perfectly fine images out of your Pentax.
    Probably shutter speed issues, or the wrong focus points. Post some images for us to see the problems.
  3. prairiewindlady
    Oct 7, 2007
    31
    Burlington, NC
    Well, I have taken my camera to my friend who has been into photography for a while and she couldn't figure out why it was blurry...but maybe you have some different ideas that could be helpful! :wink:
    Sooo...here are some pictures I took the other day. It was really bright outside...I experimented with different ISO levels before settling upon ISO200 which seemed to be the sharpest, but as you can see, even that wasn't turning out. I tried TV mode to turn the shutter speed up, but that only blacked out my pictures. Program wasn't fast enough...Action mode was what I ended up shooting on.
    Help?
    http://upload.web-album-maker.com/album/20071221/20071221101829
    [​IMG]
  4. Sideburns
    Sideburns TPF Noob!
    Aug 14, 2007
    2,796
    Windsor, Ontario
    sorry, but none of those pages exist.
  5. prairiewindlady
    Oct 7, 2007
    31
    Burlington, NC
    Yeah, sorry...I fixed it. Not sure why it was saying that...
  6. Johnboy2978
    Johnboy2978 No longer a newbie, moving up!
    Oct 21, 2004
    1,797
    30
    Southwest Virginia
    It would be helpful if you posted the EXIF info along with each picture. I have both the DS and the K10d and I can tell you that both are quite capable cameras. I have shot 2 weddings using the DS as a primary body before getting the K10d, so it can do the job.
    My guess would be you the shots are handheld and the shutter speed is too low to avoid camera shake. I'm not sure how heavy the lens is that you were using, but it has a long focal length which can make it awkward to hold steady unless the shutter speed is fairly quick. Generally a rule of thumb to avoid shake is that the shutter speed should be at least the reciprocal of the focal length of the lens. So, with that lens, the shutter speed should be at least 1/300+ to avoid camera shake. Of course, you can improve on that with practice. Try a few shots with a tripod and see what you get. If you don't have a tripod get a sandbag and see. I bet that cures your problem.
  7. prairiewindlady
    Oct 7, 2007
    31
    Burlington, NC
    Ok...I'm gonna try this again :)
    [​IMG]
    (http://upload.web-album-maker.com/album/20071221/20071221101829/slides/IMGP4801.html)
    Width: 3008
    Height: 2000
    Horizontal Resolution: 72 dpi
    Vertical Resolution: 72 dpi
    Bit Depth: 24
    Frame Count: 1
    Equipment Make: Pentax Corporation
    Camera Model: Pentax *ist DS
    Creation Software: *ist DS Ver 1.00
    Color Representation: SRGB
    Flash Mode:
    Focal Length: 158mm
    F-Number: f/5.6
    Exposure Time: 1/250 sec.
    ISO Speed: ISO-200
    Metering Mode: Pattern
    Exposure Program: Action Program
    Exposure Compensation: 0 step
  8. Sideburns
    Sideburns TPF Noob!
    Aug 14, 2007
    2,796
    Windsor, Ontario
    it looks like shutter speed is too low. perhaps the ISO could go up a notch.
  9. prairiewindlady
    Oct 7, 2007
    31
    Burlington, NC
    Ok...that's what my friend said too. ;) However when I turn up the shutter speed in TV mode, it practically blacks out the photos. Is there a way I can counter this?
  10. Sideburns
    Sideburns TPF Noob!
    Aug 14, 2007
    2,796
    Windsor, Ontario
    That's why I said bump up the ISO.
    If you double ISO, it gives one stop of light.
    Therefor, you can make the shutter faster by one stop.
    One stop means cut the shutter in half.
    so
    1/100 --> 1/200
    1/30 --> 1/60
    Get what I mean?
    Also, you can open the aperture..but I'm sure it's probably already all the way open. If not...open it up all the way. At full zoom, it's 6.3, which is pretty slow...but it'll have to do. In sunlight, you'll be fine, with lots of room to adjust shutter speed.
