Pentax or Nikon
Discussion in 'Digital Discussion & Q&A' started by thanos_tj's, Apr 19, 2017.
  1. thanos_tj's
    thanos_tj's TPF Noob!
    Jan 20, 2016
    6
    Hello guys I want to buy either the Nikon D80 or the Pentax k10d.Both of them have the same specifications with the only difference that the Pentax has optical stabilisation.What's your opinion ? For which of them do you think it would be easier to find cheaper used lenses,Nikon or Pentax and which of them should I trust ?
    Sent from my CUBOT_NOTE_S using Tapatalk
  2. limr
    limr Moderator Staff Member Supporting Member
    Jun 9, 2013
    16,508
    8,800
    Pentax. It's a better bargain - in general, Pentax gives more camera and lens for less money, and they are solid, reliable cameras. Pentax also hasn't changed its basic K-mount, so it's easier to find really good legacy lenses that would still be compatible with the K10.
  3. Peeb
    Peeb Semi-automatic Mediocrity Generator Supporting Member
    Jul 16, 2015
    2,514
    1,369
    Oklahoma
  4. Derrel
    Derrel Mr. Rain Cloud
    Jul 23, 2009
    40,024
    15,012
    USA
    Both have plenty of affordable lenses on the used market, with Nikon's F-mount being pretty popular. Both of those are older camera models, so the used market prices should be quite low. I'm not really "Up On" either of those camera models.
  5. Mofty
    Mofty TPF Noob!
    Apr 7, 2017
    9
    I always suggest "Nikon" .
  6. nerwin
    nerwin Been spending a lot of time on here!
    Jan 31, 2015
    3,130
    1,046
    Vermont
    What is your budget? That will help us give you a more informed answer.
  7. smarty62
    smarty62 TPF Noob!
    Jun 25, 2017
    24
    18
    Check out Nikon Lens Compatibility if you like to go with the D80.
    Greets, Gerhard
    Gesendet von meinem SM-G930F mit Tapatalk
  8. benhasajeep
    benhasajeep No longer a newbie, moving up!
    Top Poster Of Month
    May 4, 2006
    4,017
    494
    Are these the only 2 in your price range? The prices for these should have bottomed out and would be similar in price to even newer models.
    If your only choices between the 2. The Pentax is a slightly better camera, and sensor performance. It has body stabilization and dust cleaning options. Other than that, they came out at the same time, and were originally priced close to each other. With the Pentax costing a little bit more.
