Photo damage by water leak
Discussion in 'The Darkroom' started by nryanphx, Apr 26, 2009.
  1. nryanphx
    nryanphx TPF Noob!
    Apr 26, 2009
    5
    I have a family photo that was damaged two days ago when our hot water tank leaked. There was another photo on top of this one. The paper from the top photo has adhered to the family photo. How do I get the paper off? Since this photo is about 60 yrs. old, I asume it was developed and rinsed in a water-bath. Could I wet the photo enough to loosen the paper from the top of the image?
  2. dxqcanada
    dxqcanada Been spending a lot of time on here!
    Dec 4, 2008
    6,157
    930
    Woodbridge, Ontario, Canada
    Yes, I would think you could do that.
    The emulsion from the photo got wet, then dried, which then adhered to the photo above it.
    If you put the photo's in a water bath it should soften the emulsion and hopefully it will release from the top photo's paper backing.
  3. nryanphx
    nryanphx TPF Noob!
    Apr 26, 2009
    5
    Is plain water OK? I have no experience with this.
  4. dxqcanada
    Dec 4, 2008
    6,157
    930
    Yes, that will do.
    I have heard some suggest to use warm water.
    You may have to let them soak for a while.
  5. nryanphx
    nryanphx TPF Noob!
    Apr 26, 2009
    5
    I will try one of the smallest photos first. Thanks so much!!
  6. nryanphx
    nryanphx TPF Noob!
    Apr 26, 2009
    5
    It worked. I soaked the photo in a tub of warm water. I used a gentle scrubber to remove the adhesive from the other paper. Now, how do I dry it so it doesn't warp?
  7. TwoRails
    TwoRails TPF Noob!
    Nov 9, 2008
    1,149
    The Great Northwest
    Very interesting. I'll have to remember this trick if / when I ever need it :)
  8. dxqcanada
    Dec 4, 2008
    6,157
    930
    You could hang dry on clips ... and clip weights on bottom to keep from curling.
    When semi-dry you can take a low heat iron to do the final flattening/drying (iron on the paper backed side), put the image side on a very smooth surface ie glass or metal sheet.
    You might want to ask others in the Darkroom Forum section.
  9. dxqcanada
    Dec 4, 2008
    6,157
    930
    I forgot to add ... if they are still curly ... this is what I used to do when I printed on Fibre based paper; when prints are dry ... sandwich in a very thick book.
  10. nryanphx
    nryanphx TPF Noob!
    Apr 26, 2009
    5
    I did hang the pic. The book will be my next step. Thanks to all who helped me. The photo is over 60 yrs. old. I am so pleased to have it restored.
  11. ann
    ann No longer a newbie, moving up!
    May 14, 2007
    4,263
    189
    another thread that is over 3 years old makes an appearance. :)
  12. terri
    terri Administrator Staff Member Supporting Member
    Sep 2, 2003
    27,215
    2,770
    In the mental ward of this forum
    :scratch: At least the info is okay.
