Photo scanner/printer.
Discussion in 'Beyond the Basics' started by gender bombs, Mar 16, 2006.
  1. gender bombs
    gender bombs TPF Noob!
    May 9, 2005
    93
    New York
    Hey, just have a few questions. Okay, let's start off by saying money is no problem at all here. If I wanted to blow up a normal 4x6 or 5x7 photograph to let's say, 8.5x11, without being grainy or any other changes in quality form the original, what Photo scanner/printer would you suggest. Replys are greatly appreciated. Thanks:D
  2. Rob
    Rob TPF Noob!
    Jan 29, 2005
    6,217
    134
    London
    It's not really possible to do this well with a flatbed scanner scanning a print as you are trying to add information which isn't there.
    Consider a negative scanner for this job. I'd recommend any of the Epson photo printers.
    Rob
  3. Alpha
    Alpha Troll Extraordinaire
    Mar 15, 2005
    5,454
    41
    San Francisco
    The Epson 16xx (insert two numbers there) series flatbed scanners produce surprisingly good results when used with the optional transparency cover for scannning negatives. Nikon makes the best consumer grade negative scanners.
  4. gender bombs
    May 9, 2005
    93
    New York
    Do negative scanners just put the negative onto the computer? What do they do?
  5. Alpha
    Mar 15, 2005
    5,454
    41
    San Francisco
    Yep. Negative scanners will only scan negatives or color positives (slides), not prints.
  6. gender bombs
    May 9, 2005
    93
    New York
    How much do they cost?
  7. Alpha
    Mar 15, 2005
    5,454
    41
    San Francisco
    lol I thought money was no problem ;) . Anyway, cost really depends on whether you need to scan medium format, or just 35mm. They range from a few hundred to a few thousand dollars, depending on their capabilities. If you need to scan MF film but don't have the cash for a film scanner that can handle it, your best bet is to buy the nicest Epson flatbed you can afford that has film scanning abilities (i.e. a transparency lid and 35mm and 120 film holders).
  8. gender bombs
    May 9, 2005
    93
    New York
    Money is no problem:D , just wanted to get an idea. Okay, so I'll look for a really good Epson, then I'll try to find a negative scanner as well. Thanks for all of your help.:thumbup:
  9. Alpha
    Mar 15, 2005
    5,454
    41
    San Francisco
    Sure, no problem. The Nikon Super Coolscan and Minolta Dimage series are the best negative scanners. Steer clear of Polaroid.
4x6 5x7 photo printer with scanner
how to blow a photo up with a scanner
how to blow up 4x6 picture to 8.5x11
how to blow up a 5x7 to an 8.5x11
scan 4x6 and 5x7 pic
