Bifurcator
- Joined
- Jun 1, 2008
- Messages
- 3,312
- Reaction score
- 1
- Location
- Japan
- Can others edit my Photos
- Photos OK to edit
Photo to Movie enables you to create a movie by zooming and panning over a photo. It presents a simple interface to specify the starting and ending frames and generates full quality QuickTime or DV Stream files (compatible with iMovie).
Use Photo to Movie to:
The major new features:
- Graphically select the starting and ending frames
- Select the position and zoom of the starting and ending frames
- Preview the starting and ending frames as you edit them
- Preview the entire movie during editing
- Drag desired images directly into the configuration window
- Drag and drop photos directly from iPhoto
- Set the length of the exported movie
- Export NTSC 29.97 fps 720x480 4:3 video suitable for iMovie
- Export PAL 25 fps 720x576 4:3 video suitable for iMovie
- Export movies to QuickTime or to DV Stream
- Import DV Stream directly into iMovie
- Title Effects: A new title rendering system has been added along with the ability to add title effects. Before only fade in and fade out were available. Now you can choose to animate your titles into and out of the movie. The current in and out effects include Fade, Move, Scale, and Typewriter. Give them all a try by selecting a title in the timeline, clicking on the effect tab, choose either Effect In or Effect Out, and setting the desired Effect. Then play the title in the timeline.
- Gather Media: You can have Photo to Movie copy your photo and audio files to a common folder for archiving. Use the menu item File > Gather Media... You'll be asked to choose a folder and once all the files are copied you'll be asked to save your modified Photo to Movie document that includes references to the media files in their new locations.
- Alternate Aspect Ratios: You can now render movies at aspect ratios other then 4:3 or 16:9. Most users will not need to do this, but if you do, set your aspect ratio in Document Info to 'Same as Movie Size'. Then set the Movie Size on the right. Your key frames and final movie will have the aspect ratio width:height.
- Fit to audio: Menu item Audio > Fit Photos to Audio (Shift-Cmd-F). This instantly stretches or shrinks your photo track to match the duration of your audio track.
- Quickly move between photos: Cmd-[ and Cmd-] to move selection to the previous and next photos.
- Contextual menus: Right click on a photo in the timeline to open it in an external editor or reveal it in the Finder.
- Performance: We know that the Preview and Full Screen performance is less than stellar in recent versions of Photo to Movie. We're working hard to remedy this situation and this new version partially addresses this issue by making thumbnail processing more seamless and taking less CPU time and using optimized OpenGL more frequently than CoreImage. Please let us know how things are working on your particular machine!
- Stability: Photo to Movie 4.1 and 4.2 both include a crash reporter that sends crash reports directly to our servers. If either of these versions crash on you, please re-launch the software and submit the crash report. We examine each crash report carefully to figure out what went wrong. The Crash Reporter has led to numerous fixes in the last few months that have dramatically reduced the number of crashes.
- Mac OS X 10.4 or later.
