Photograph processing
Discussion in 'Beyond the Basics' started by nem, Sep 26, 2004.
  1. nem
    nem TPF Noob!
    Sep 26, 2004
    7
    Hey,
    When you take photos on a non-digital camera and it is getting processed do you get worried about the outcome?
    Is it normal? Everytime i get the feeling they will come out bad!
  2. tr0gd0o0r
    tr0gd0o0r TPF Noob!
    Jun 29, 2003
    942
    4
    Shreveport, Louisiana
    Very normal, especially when developing your own film
  3. Walt
    Walt TPF Noob!
    Feb 12, 2004
    1,054
    BC
    I didn't help that feeling the other night when I developed a roll of b&w 120 and ended up with a roll of clear plastic! Doh! :(
  4. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    Today's sign that the Apocalypse is upon us...people are referring to film cameras as "non-digital" cameras.
  5. PrimaryCanary
    PrimaryCanary TPF Noob!
    Aug 29, 2004
    145
    Caution: Contents Under Pressure
    Maybe analog or traditional would be a better term? :D
  6. gecko
    gecko TPF Noob!
    Sep 27, 2004
    98
    Southern Tier
    film is like a computer
    it does what it is made to do
    with your problem
    either u DIDNT feed the film properly into the camera
    or
    you used fixer before developer
    had that problem myself when i first started :oops:
  7. Walt
    Walt TPF Noob!
    Feb 12, 2004
    1,054
    BC
    I believe it was a case of "This old developer should be good for one last roll!" Hard to load the film wrong in the camera and not catch it. Starts on one reel and ends up on the other. Still, in the end, my fault. :(
  8. gecko
    gecko TPF Noob!
    Sep 27, 2004
    98
    Southern Tier
    thats not neccesarily true though
    in one class i was teaching about 5 of the students have done it at one point or another
    even after i gave a warning about it
    sometimes the film catches, then gets uncaught
    it happens
    i mean u may be right, but it happens
  9. ksmattfish
    Aug 25, 2003
    7,019
    35
    Lawrence, KS
    What you say is possible with 35mm film, but with 120 film if it ends up on the take-up roll, then it had to go through the camera (no rewinding for MF). Many modern medium format cameras won't even let you take photos if the film is not advancing through the camera correctly.
  10. oriecat
    oriecat work in progress
    Jul 7, 2003
    3,117
    19
    Portland OR USA
    That totally sucks, Walt. I did that last spring myself. Lost two rolls of vacation pics to dead del. :(
  11. Walt
    Walt TPF Noob!
    Feb 12, 2004
    1,054
    BC
    Oh well, lesson learned! While I don't relish the thought of mixing powders that seems to be the only practicle solution considering the frequency I use my darkroom. Or....maybe I should be using the darkroom more often?!
  12. gecko
    gecko TPF Noob!
    Sep 27, 2004
    98
    Southern Tier
    my fault missed the 120
