Photographer at International Poker game
Discussion in 'Beyond the Basics' started by andrewaaa5, Sep 15, 2004.
  1. andrewaaa5
    andrewaaa5 TPF Noob!
    Sep 15, 2004
    10
    Hi,
    I am going to take photos at a major Internatinoal poker tournament.
    The low light levels would normally require a flash to be used, or a tripod.
    High ISO settings on my digital camera (G3) will not be sufficient to take the pictures at fast shutter speeds. to take longer exposures I would need a tripod. I do not want to use tripod.
    Has anyone had any experience at such an event?
    I want to use a flash (EX420) but I do not want to destract the players.
    Any advise greatly appreciated.
    Andrew
  2. santino
    santino TPF Noob!
    Jun 17, 2004
    2,240
    12
    Austria, heart in Poland -->
    hmmm.... you may try to bounce the flash of the ceiling or a wall, hope that helps :)
  3. andrewaaa5
    Sep 15, 2004
    10
    the ceilings are very high and the room very big.
    i was going to use that good old trick of pointing the flash head straight up to the ceiling and putting a piece of white paper behind the flash, but still this omits a lot of light and may be distracting to the players.
    I guess I should really post this question in a poker/casino forum.
    Andrew
  4. Walt
    Walt TPF Noob!
    Feb 12, 2004
    1,054
    BC
    Switch to a film camera with high speed film for the event. If possible with an IS lens.
  5. markc
    markc TPF Noob!
    Mar 8, 2004
    4,237
    6
    Rochester, NY Velocity: Unknown
    And use a fast prime lens (or two), like f1.8.
  6. Evan55T
    Evan55T TPF Noob!
    May 17, 2015
    61
    4
    NJ
  7. JonA_CT
    JonA_CT TPF Supporters Supporting Member
    Dec 19, 2015
    1,105
    761
    New London, CT
    The great thing about flicker is it posts EXIF data. The first two pictures were taken at 68 and 50mm on FF (and without flash).
    I'm going to guess that 50mm will probably be okay, and you'll have to hope the high ISO performance of your camera is good.
  8. Evan55T
    Evan55T TPF Noob!
    May 17, 2015
    61
    4
    NJ
    I'm currently using a *used* d7000 nikon and yeah i really wanna try to get the cleanest/clearest shots possible without any noise/grain in them
  9. Drive-By-Shooter
    Drive-By-Shooter No longer a newbie, moving up!
    Sep 8, 2016
    191
    51
    North Carolina
    right; he does not want a wider lens.
    50mm should suffice,
    but a longer lens like a 85mm or even a 135 will get better portraits with the subject "popping out" from the background like his 1st and 3rd examples.
  10. Evan55T
    Evan55T TPF Noob!
    May 17, 2015
    61
    4
    NJ
    Yeah man thank you for the reply and response! :)
    Well i actually asked this poker photographer and he said a wide angle lens is a must altogether as well as just a reg prime lens like a 85mm or 50mm. For the most part you are taking portrait shots of the players mostly though some shots work really well with a wide angle lens that u wudn't be able to get with a prime
    • Like Like x 1
  11. freddy21
    freddy21 TPF Noob!
    Nov 17, 2016
    16
    4
    Edmonton AB Canada
    I would just watch carefully if using a 50mm or less as they tend toward pretty large apertures. Although they are good for low light they will also give you a really shallow DOF when wide open.
    I might think about an LED panel light rather than a flash. Steady light won't disturb as much as a flash.
  12. Evan55T
    Evan55T TPF Noob!
    May 17, 2015
    61
    4
    NJ
    I have another question in regarding sensors...
    What's the diff between a Full-frame sensor vs. APS-C?
    Reason i'm asking is i currently have a d7000 that is an APS-C and i was wondering if full-frame sensors (like a d700 or other dslr camera) would be better for poker/portrait photography in low light conditions?
    (full-frame)
    D70_1034
    (APS-C)
    Haykel Vidal
andrew parsley
andrew parsley las vegas
andrew parsley las vegas poker
andrew parsley poker
andrew parsley poker book
andrew parsley poker player
andrew parsley professional poker player
andrew parsley wsop
andy parsley poker player
poker player photography
