Photographing people with glasses
Discussion in 'Beyond the Basics' started by ajmall, Apr 9, 2006.
  1. ajmall
    ajmall TPF Noob!
    Mar 24, 2004
    656
    Leicester, UK
    I'd like to know any methods you people use to avoid getting reflections of flashes on people's glasses? I've tried all sorts of ceiling and wall bouncing but I'd always end up with a white light in both lenses of the specs.
  2. Paul Ron
    Paul Ron TPF Noob!
    Oct 11, 2003
    498
    7
    NYC
    If they can't take em off, use a polarizing filter.
  3. ajmall
    ajmall TPF Noob!
    Mar 24, 2004
    656
    Leicester, UK
    my god that was so obvious. d'oh! haven't used a polarizing filter for a long time so maybe that's why i didn't think of it
  4. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    Get a precision screw driver and remove the lenses from the frames. It can be time consuming but will solve the problem.
  5. Glorsclaws
    Glorsclaws TPF Noob!
    Jan 1, 2006
    31
    UK
    I dont know if this works but I read that if you cant take the glass out of the frames then angle the specs so the glass points slightly down with the frame raising up above the ear, the tilt is supposed to avoid some of the glare!
  6. Rob
    Rob TPF Noob!
    Jan 29, 2005
    6,217
    134
    London
    Have them stand at a 45deg angle to you and light them from their behind (about 45deg to you and 90 to them). That way, the light is cast from the rear of their glasses, removing any shadows on cheeks and preventing the need for a full-facial rabbit headlight shot.
    Rob
  7. ajmall
    ajmall TPF Noob!
    Mar 24, 2004
    656
    Leicester, UK
    I take it you mean using studio lights? My original post was for use with an on camera flash though that's good advice. Thank you
  8. Christie Photo
    Christie Photo No longer a newbie, moving up!
    Jan 7, 2005
    7,067
    87
    Kankakee, IL
    This is the way the pros have done it for years. And, it does work!
    Pete
  9. bobbinika
    bobbinika TPF Noob!
    Dec 7, 2005
    8
    I took some passport photos awhile ago and if you have them tilt their head up or down a bit.. it should get rid of reflections:thumbup:
photographing people with glasses
