photomatrix seems to soften my images
Discussion in 'Beyond the Basics' started by notelliot, Jul 6, 2007.
  1. notelliot
    notelliot TPF Noob!
    Nov 13, 2005
    827
    i've got two images here, one an hdr generated with 3 images, 2 stops apart using photomatrix pro, and one normally exposed image. all shots were made with a tripod, and were aligned when i generated the hdr. photoshop did nothing to sharpen the image after the fact.
    here are the images:
    [​IMG]
    [​IMG]
    the original files were really crisp.. hdr.. not so much. i know a few of you are familiar with photomatrix.. any ideas? maybe i'm just being fussy. thanks in advance.
  2. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    HDR is not an exact science...the software is probably merging tones that would otherwise have been sharp detail. It could also be slight variations in the images...maybe the wind was blowing more in one image?
    You could try to blend the exposures manually.
  3. notelliot
    notelliot TPF Noob!
    Nov 13, 2005
    827
    it's not just this one image. it softens everything i generate. i think i should start using my remote release for these, if anything. .. and try blending manually
  4. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    So are you using a tripod but manually pressing the shutter release? Why not use the self timer?
    Personally, I'm not usually thrilled with the results I see from automatic HDR functions.
  5. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    I've never had problems with soft images before with photomatix. If something was wrong with it, it's generally my fault.
  6. notelliot
    notelliot TPF Noob!
    Nov 13, 2005
    827
    hahahah, thanks for pointing out the lack of an r. makes more sense now!
  7. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    The mapping radius is high in the image you posted. This is the result of tone mapping over a large area. It's a fault of the HDR process not the software itself.
