Photoshop CS2 help...PLEASE!!
Discussion in 'Graphics Programs and Photo Gallery' started by Point-N-Shoot, Nov 3, 2006.
  1. Point-N-Shoot
    Point-N-Shoot TPF Noob!
    Sep 18, 2006
    33
    Dallas, Texas
    There is something very wrong with my PSCS2. Photos view VERY washed out when opened in Photoshop CS2. I am having a hard time making adjustments to my pics because I have to save the file and then open it in ACDSee to see what the pic REALLY looks like.
    Here is screen shot of a photo I took opened in PSCS2 and ACDSee (right)...
    [​IMG]
    As you can clearly see, the PSCS2 photo is desaturated. This is NOT a problem with my camera...even stock photography that came with Adobe Lightroom comes out looking the same way...ALL photos do. Here is the profile I started with...
    [​IMG]
    I've tried changing the color profile and I've even hit Ctrl+Alt+Shift when opening PS (to reset back to the default settings)...nothing has worked.
    Again...this is NOT just with pictures from my cameras...stock professional photographs look the exact same way. Could my software be corrupted?
    I'm using Adobe PSCS2 (version 9.0.2) in Windows platform with an NEC MultiSync 22" CRT monitor on an NVIDIA GeForce FX 5900 Ultra graphics card, and I've update the drivers for both my monitor and card.
    Thanks
  2. dewey
    dewey TPF Noob!
    Sep 14, 2006
    650
    29
    The Space Coast of Florida
    If the same phot can be opened in another app and it's NOT desaturated then it wasn't desaturated in CS2... it's just displaying that way. Curious if you start with a new file are create some color strokes... are they also washed out? There are a few possibilities with the display we may want to check.
    Has it always done this from the time you installed it?
    ~Dewey
  3. Arch
    Arch Damn You! Staff Member Supporting Member
    Jan 21, 2006
    8,487
    102
    locked in the attic
    There isnt anything wrong with the colour menu that i can see.... you may want to check the 'assign profile' menu.... make sure thats on adobe 1998 or sRGB...
    If you can't locate the problem... you could try switching all the PS settings back to defult... that way if you did change anything by mistake, it will make sure you've covered all bases before you try anything else.
    Nothing else springs to mind at the moment...
  4. Point-N-Shoot
    Sep 18, 2006
    33
    Dallas, Texas
    Yes, I meant to say the the PSCS2 photos APPEAR desaturated, which is making it harder for me to do post processing.
    HMMMM...I'll try that when I get home this evening.
    YES, from the very beginning...could it be a corrupt install?
  5. Point-N-Shoot
    Sep 18, 2006
    33
    Dallas, Texas
    Where do I find the "Assign Profile" menu??
    Already done (as stated in my original post).
    Thanks for the input.
  6. Mohain
    Mohain TPF Noob!
    Dec 29, 2005
    1,863
    11
    London, England.
    Have you got view>proof colors ticked? If so, untick it.
  7. Point-N-Shoot
    Sep 18, 2006
    33
    Dallas, Texas
    Well, I found the problem (other than I'm fu*king stupid).
    I was under the (mis)assumption that Adobe Gamma was an automatic profiling script within PSCS2...not an actual program that you have to run through. I discovered this from someone on a Photoshop forum, so I ran through the Adobe Gamma Wizard calibration and —voilà!— immediate color improvement.
    Here is the AFTER pic...
    [​IMG]
    Still a tiny bit off, but WAY better than before...and definitely manageable. It will be even better once my Monaco Optix XR arrives.
    Dave
  8. markc
    markc TPF Noob!
    Mar 8, 2004
    4,237
    6
    Rochester, NY Velocity: Unknown
    Do you have proofing on? If so, it should only be used to proof prints, and the profiles should be printer(+ink+paper) profiles, not monitor profiles.
  9. AccidentalArt
    AccidentalArt TPF Noob!
    Dec 12, 2006
    Houston
    can you post some details on how to do the gamma calibration?
    Thanks
  10. drkuba
    drkuba TPF Noob!
    Nov 16, 2006
    33
    quick question regarding this: what color managment should someone use to mimick what a photo will look like when printed off of a site such as shutterfly?
  11. markc
    markc TPF Noob!
    Mar 8, 2004
    4,237
    6
    Shutterfly should have an ICC profile you can use for proofing. If it's not on their webpage, e-mail them and ask.
