Photoshop is messing up. Help please
Discussion in 'Photography Beginners' Forum' started by eric-holmes, Mar 23, 2010.
  1. eric-holmes
    eric-holmes No longer a newbie, moving up!
    Aug 8, 2009
    1,858
    49
    Arkansas
    For some reason, no matter what tool I click, only the hand appears. I can't do anything because all it will let me use is the pan tool. I shut the computer down and restarted it and it went back to normal for a short bit and then it locked to the pan tool again. Any ideas? It's like it's on the fritz. Now it is back to working normal. But once I get into editing it will "lock" to the pan tool.
  2. DRoberts
    DRoberts TPF Noob!
    Apr 18, 2008
    780
    Springfield, Missouri
    If you still have the program disc try uninstall and reinstall.
  3. Bitter Jeweler
    Bitter Jeweler Been spending a lot of time on here!
    Apr 27, 2009
    12,984
    4,971
    Cleveland, Ohio
    Are you leaning on the spacebar?
  4. thebeatles
    thebeatles TPF Noob!
    Oct 30, 2007
    805
    pennsylvania
    This happens to me every once in a while. It is not a permanent problem. I heard it has to do with memory issues. I usually clean my comp up a bit and restart to fix this problem.
  5. burstintoflame81
    burstintoflame81 TPF Noob!
    Aug 7, 2009
    729
    Arizona
    CS4 has a glitch that occasionally surfaces for me. Sometimes I will not be able to change any colors other than like gray and white. Usually if you get a glitch you can reset all the defaults by pressing CTRL-ALT-SHIFT when opening photoshop. It will ask you if you want to delete the settings ( or something like that ) Click yes. All of your preferences will need to be reset because they will all revert to the default, but this usually fixes and glitches for me.
  6. KmH
    Apr 9, 2009
    40,077
    5,454
    Iowa
    Check your caps lock too.
    Close Photoshop.
    Edit: Like burstintoflame81 said......:lol:
    Double-click the Photoshop icon to start it again after it has had time to close.
    Immediate hold down the Ctrl+Alt+Shift keys to reset it to all the default parameters.
    You should be good to go.
  7. eric-holmes
    Aug 8, 2009
    1,858
    49
    Arkansas
    Lol no, but when I press the spacebar the flitch goes away. Thanks for everyones quick help.
