PhotoShop: Panoramic Question
Discussion in 'Photography Beginners' Forum' started by bp4life71, Dec 4, 2009.
  1. bp4life71
    bp4life71 TPF Noob!
    Sep 6, 2009
    188
    Massena, NY
    Ladies and Gents,
    To do panoramic in Photoshop, do I take a few pictures side by side and then they stitch them together laterally? How do you make them match up?
    New here on this, so the answer might be obvious, but not for me.
    Thanks!
  2. Inst!nct
    Inst!nct TPF Noob!
    Sep 16, 2009
    702
    Troll, Wisconsin
  3. ann
    ann No longer a newbie, moving up!
    May 14, 2007
    4,263
    189
    when taking the photos you need to overlap about 25-30%, keep the exposure the same, if necessary change shutter speed, not fstop so you maintain the same DOF.
    i agree with the above, there are better stitching options than photoshop.
    the software will do all the work if you have given enough overlapping.
  4. Inst!nct
    Inst!nct TPF Noob!
    Sep 16, 2009
    702
    Troll, Wisconsin
    ah forgot to mention you will NEED a tripod, and shoot in manual mode, with preferably the same focus
  5. creisinger
    creisinger TPF Noob!
    Oct 19, 2009
    470
    Miami
    Photoshop CS4 has a pretty useful interface for panoramic images but there are much better tools out there.
    Get PTGUI Download PTGui or PTGui Pro - PTGui for a free test run - this software does a good job.
    As "ann" mentioned before:
    - Use a tripod (easier but not a must)
    - all settings have to be at manual (ISO, aperture, shutterspeed, white balance AND focus!!!)
    - overlap 30% or even a bit more, depending on what you are shooting. A scene with little details like a sky with very few clouds could give you a problem if you only overlap 20% or so.
    A panoramic scene with a forest is less of a proble due to the many details that help the software to identify overlapping points.
    Good luck!
  6. battletone
    battletone TPF Noob!
    Sep 22, 2009
    285
    Somewhere in the lower 48.
    I don't see why need is emphasized.
  7. creisinger
    Oct 19, 2009
    470
    Miami
    Well a tripod will indeed help to produce better quality. I don't think it's "easier" to do it hand held.
    For someone starting out with panoramic images it's a great help to use a tripod - it eliminates a few issues that a beginner will run into such as not perfectly sharp images which make it harder for the software to align them, same height of horizon in each shot (if shot horizontally) and most importantly the pivot point barely moves while tripod mounted compared to hand held which can be a major issue if you have objects in the very close foreground.
    Having a tripod mounted on a regular tripod may not be the best solution but still better than hand held.
  8. battletone
    Sep 22, 2009
    285
    Yes, but none of that equals capital NEED, as in, you can't without.
  9. creisinger
    Oct 19, 2009
    470
    Miami
    True.
  10. jnm
    jnm TPF Noob!
    Sep 9, 2009
    297
    Palo Alto, CA
    you don't need a tripod. ive made some great panos handheld.
    CS4 is as simple as it can be to stitch them together. i just asked a similar question in the 'beyond the basics' section. whats nice about using photoshop is you can make your lightroom edits first then send them directly to photoshop.
  11. Inst!nct
    Inst!nct TPF Noob!
    Sep 16, 2009
    702
    Troll, Wisconsin
    i guess youre right, but still, in my opinion, cheap tripod = 50 dollars, wasting time on photoshop trying to straighten your picture = worth some money too
  12. Hooker771
    Hooker771 TPF Noob!
    Oct 20, 2009
    332
    Also shoot vertically, when you go to crop the photo you will be glad you did. Also when you blow them up to print they are much wider and look much better
