Pinhole diameter measurement
Discussion in 'Alternative Techniques & Photo Gallery' started by Torus34, Apr 15, 2006.
  1. Torus34
    Torus34 No longer a newbie, moving up!
    Jan 26, 2006
    2,117
    37
    Tottenville, Staten Island, NYC USA
    I don't have a microscope with a reticle available but I did want to be able to accurately measure the diameter of pinholes and the width of aperture slits. So . . .
    I shot a close-up of a graduated scale with a 35mm camera. I then measured the length of the scale on the negative between two widely spaced primary markings, say around 1 to 1 1/4 inches apart. [This in turn gave me the exact spacing between any two of the finest graduations, by the way.]
    The rest was simple. Cranked up an enlarger head to the top of the column. Put in the negative and focussed on a white sheet of paper. Marked the two measured divisions on the paper as reference marks. I then knew the magnification factor of the enlarger. Took out the negative and put the pinhole plate in the negative carrier. Marked the diameter of the light spot on the paper. Measured the diameter [I used a vernier caliper, but a good ruler would serve.] Multiplied by the factor. Voila!
    No enlarger? Use a slide projector. No slide projector? Cob-house one up using any convenient light source and any simple lens.
  2. mysteryscribe
    mysteryscribe TPF Noob!
    Feb 1, 2006
    6,071
    in the middle of north carolina
    Man you are way smarter than me. I applaud you. but I would be totally lost. The best I can even come close to relating to that, was shooting a ruler next to a footprint so we could make a one to one print.
    Sounds like a very scientific project though.
  3. JamesD
    JamesD Between darkrooms
    Mar 20, 2005
    1,019
    11
    Living in Snapshot reality.
    Good idea! Wish I'd thought of it... glad you did and posted it. Thanks ya!
