Pinhole Shutter Speed?
Discussion in 'Alternative Techniques & Photo Gallery' started by Jestpg, Nov 17, 2006.
  1. Jestpg
    Jestpg TPF Noob!
    Oct 24, 2006
    9
    Grand Rapids, MI
    I just made myself a DIY pinhole by putting a hole in the body cap of my camera. the problem is is that i have never used a pinhole camera, how do i calculate shutter speed? also what speeds of film would anyone reccomend? any help or other information would be greatly appreciated.
  2. Torus34
    Torus34 No longer a newbie, moving up!
    Jan 26, 2006
    2,117
    37
    Tottenville, Staten Island, NYC USA
    You can work out the f stop by measuring the diameter of the pinhole, etc., or you can just take a roll of film and run a test series of exposures. The method used will depend on whether you wish to spend time or money.
  3. Steph
    Steph No longer a newbie, moving up!
    Oct 18, 2006
    1,314
    Steventon, Oxfordshire, UK
    Have a look at this website:
    http://www.pinhole.cz/en/pinholedesigner/
    With this freeware you can calculate the f stop of your camera (if you know the distance from film plane to pinhole and the diameter of the pinhole). Once you have your f stop you can then calculate exposure times for various films (the calculator even takes reciprocity failure into account for most common films) . You can use that as a guide to shoot a test roll.
    Speeds of film depend on what you want to achieve. I use Ilford Pan F (50 ISO), FP4+ (125 ISO) and HP5+ (400 ISO) for B&W pinhole pictures and Fuji Reala for colour pictures when the exposure is not too long otherwise you get a very noticeable colour cast.
  4. mysteryscribe
    mysteryscribe TPF Noob!
    Feb 1, 2006
    6,071
    in the middle of north carolina
    If you were very pricise with your hole try this site http://mrpinhole.com/ if not experiment like Mr T suggested. You might also set your camera up aperture priority and let your camera meter do the work if yoiu have one that will. It should be a lot exposure if not your hole is too big.
  5. geoffe
    geoffe TPF Noob!
    Nov 5, 2006
    48
    Michigan
    Is that body cap for a digital slr or a film slr? Reason I mention this is I made pinhole a body cap for a digital slr once and it destroyed the sensor. Second of all the digital pinhole needed to be very precise. I began with a .10 and it was a bit on the soft side. Going to .09 made a huge difference. For some reason the focal length does not make much of a difference on a film camera like it does on a digital. I learned that next time I make a pinhole cap for a digital slr, I will cover the pinhole with glass. Dust is a pain in the butt to get off the sensor.
  6. Jestpg
    Jestpg TPF Noob!
    Oct 24, 2006
    9
    Grand Rapids, MI
    it is a film camera, thanks for all the help!
