Plaubel Makina 67 – problem with shutter/winder, please help.
Discussion in 'Medium Format & Large Format' started by Marcush, Aug 12, 2010.
  1. Marcush
    Marcush TPF Noob!
    Aug 12, 2010
    Sweden
    Hi, I just bought a Makina 67. The lightmeter and all shutter speeds work excellent, but I've got a problem. When I load it (120 film of coarse) and close it, the shutter won't fire. It's looked in the upper position. But if I open the camera back a little, it works. So I close it, wind it, and then it's stuck again. Is anyone familiar with this problem? Do you have any idea what's wrong? All answers are much appreciated.
    Kr,
    Marcus
  2. Helen B
    Helen B TPF Noob!
    Sep 16, 2007
    3,296
    465
    Hell's Kitchen, New York
    Marcus,
    I hope that someone will chime in with a better answer than mine, but I will add what I can. I have a 67 and a W67, both of which have been overhauled at Nippon Photo in New York - one of the best places remaining for Makina repairs as far as I know. Maybe you could give them a call if no-one has any other suggestions.
    Nippon Photo Clinic
    920 Broadway
    New York, NY 10010-8018
    (212) 982-3177
    Sorry I could not be more help.
    Good luck,
    Helen
  3. Marcush
    Marcush TPF Noob!
    Aug 12, 2010
    Sweden
    Helen, thanks for your reply. I really hope it's just an easy fix, and that sending it to NY or Germany won't be necessary. But I'm afraid it will be. Either way, thanks for the tip!
    /m
  4. Helen B
    Helen B TPF Noob!
    Sep 16, 2007
    3,296
    465
    Maybe a phone call to Nippon first, to see if they have come across the problem before and know of an easy fix.
    Can you isolate whether it is the back that is causing the problem directly or the reset pin? If you open the back until everything works, does pressing the reset pin (the one that is pressed by the back when it closes) cause the problem even though the back is still open?
    Good luck,
    Helen
  5. Marcush
    Marcush TPF Noob!
    Aug 12, 2010
    Sweden
    Hi, with the back open but the reset pin pressed, the shutter is stuck. And when i release the pin it works fine. Does that tell you anything?
    Yeah, maybe a phonecall to Nippon is in order. Or do you know if they have an e-mail adress? Tried to visit their website but I couldn't get in.
    Ps. Didn't even know that's a reset pin til you told me. I guess that's what turns the frame counter back to zero?
makina 67
makina 67 repair
makina 67 shutter
pintil.photo
plaubel makina
plaubel makina 67
plaubel makina 67 problems
plaubel makina 67 review
plaubel makina repair
plaubel makina w67
