Playing with Elements
Discussion in 'Critique Forum Archives' started by jocose, Sep 28, 2005.
  1. jocose
    jocose TPF Noob!
    Sep 16, 2005
    3,059
    118
    dans la pissoir
    Hey gang,
    Here's a picture I'd like some feedback on. I'm trying to learn how to use Photoshop Elements (I'm actually using the freebie I downloaded from them at the moment), so last night I was playing with the color controls.
    My primary concerns are the colors and levels and all that, but please feel free to make any other comments as well.
    I can't relly remember too much about what I did because I don't really know what I did. I played around with the hue and saturation under the Master dropdown, then I went into the yellow (I believe) and adjusted that a little, and finally went into the Red and brought that up a wee bit.
    Anyway, please tell me how to make it better or different or more fun or more interesting, etc.
    Thanks as always...y'all are really great!
    [​IMG]
  2. tigerallied
    tigerallied TPF Noob!
    Sep 14, 2005
    16
    Bucharest
    ouch !!
    fisrt of all you playd to much with the colors (look at the fish line handle and you will know what i'm talking about)
    you horizont line is bend to the right
    the photo is to "crowded"
    and try to have onley one subject ... you have tree the ponton, the fishing lines and the bridge
    ou and the boat is all so tilted th the right
  3. eydryan
    eydryan TPF Noob!
    Sep 13, 2005
    428
    7
    Bucharest, Romania
    i wanna see more sky. and i don't like the wooden plank, at least not saturated like this.
    and if you're into downloading why don't you cross to the other side and download some photyoshop tutorials. join the dark side :D
  4. jocose
    jocose TPF Noob!
    Sep 16, 2005
    3,059
    118
    dans la pissoir
    tutorials?? I'm not sure I know what that is ;)
    To get more sky, do you think that it might have been more interesting to get lower and have a sharper upward angle? That way I could get the rods AND more sky?
  5. eydryan
    eydryan TPF Noob!
    Sep 13, 2005
    428
    7
    Bucharest, Romania
    yes that would be interesting, also, try using a wider angle and getting real close to the base of the rods and you'll get a more dramatic look.
    and tutorials are stuff (mainly videos but also books audio etc) which tells you exactly what you can do with photoshop and how.
  6. jocose
    jocose TPF Noob!
    Sep 16, 2005
    3,059
    118
    dans la pissoir
    OK, first off, I was only teasing about not knowing what tutorials were ;) But I appreciate the info.
    Secondly, as I'm still new, let me ask. A wider angle would flatten things more and get more things in the frame, but being up close and pointing upwards would also skew the prospective dramatically, correct?
    While my camera can accept some kind of adapter lens, it's basically an advanced point-and-shoot, so if I were to just keep the lens at the widest setting (as opposed to zooming in, which I did a bit), would that work better?
  7. eydryan
    eydryan TPF Noob!
    Sep 13, 2005
    428
    7
    Bucharest, Romania
    well fmpov that is a desired effect, the distortion caused by the wide-angle lens, because it creates a different perspective upon the fishing rods. also it is not necessary to have a very wide wide angle :D to create this effect, because straight rods we see every day, but from below and wide angle more rarely. and a wide angle does not flatten, on the contrary, it curves.
    and normally the type of camera you probably use is a digital compact which should have its wide angle at around 38mm which is good because it isn't that much of a distortion but it's there.:D
    and about the tutorials well there may be some people who actually don't know... :D i just like to be helpful :D
  8. jocose
    jocose TPF Noob!
    Sep 16, 2005
    3,059
    118
    dans la pissoir
    I appreciate your help :hail: I meant no offense by my comment, and I'm grateful that I found this forum!
    As to focal lengths. I have a Canon PowerShot S2 IS. According to the specs web site, the focal length is 6.0 - 72.0mm f/2.7-3.5 (35mm film equivalent: 36-432mm). I assume that that is good?
    Sadly, while you offer great advice, I don't know if I could ever recreate that shot. It was taken on a fishing boat that we went on 2 Friday's ago in New Jersey. I was up there for my sister's wedding and the groom and his boys went out deep sea fishing on Friday while the girls got their nails done.
  9. eydryan
    eydryan TPF Noob!
    Sep 13, 2005
    428
    7
    Bucharest, Romania
    yes, it's a great forum indeed, i'm just so sad i can't afford to spend more time on it, there are just so many things which need to be said.
    your camera i have heard is really good and about the focal distance yeah it's cool. lower, just bit to around 26-28 would be perfect but 36 is also good.
    the recreation of the shot isn't necessary to learn, the principle is. you understand what you can do in order to make your shot have more impact. but well that's a lot about your vision and no one can tell you actually how todo that. just give you small tips and tricks :D
  10. jocose
    jocose TPF Noob!
    Sep 16, 2005
    3,059
    118
    dans la pissoir
    I like my camera a lot, but I really want to move up to a DSLR. I just can't rationalize the cost yet since I'm still so new at it. that is actually why I went with the one I got...it's got more than mere point and shoot capability, but it's still a nice point and shoot...kind of like a camera with training wheels :)
    You are right that the technique is what's important, and I will get out this weekend (except it's supposed to rain) and see what I can do.
  11. eydryan
    eydryan TPF Noob!
    Sep 13, 2005
    428
    7
    Bucharest, Romania
    the dslr or slr for the matter have a range of features which you will find are way better than the slr-style compact that you currently own. however, in my oppinion your digital camera is quite a good one and you should stick to it aleast until you'll find some moron who sais: that is in our oppinion a lame asss camera. please buy a beetter one before submitting pics. and then you'll buy a dslr :D
    rain can be a great subject at night especially on asphalt (all the lights are reflected by the road) but maybe it's also good just like it is. i dunno, couldn't quite find a good way to shoot rain yet :D
  12. jocose
    jocose TPF Noob!
    Sep 16, 2005
    3,059
    118
    dans la pissoir
    Can't the rain ruin the camera? Do you need one of those waterproof cases?
