Please critique
Discussion in 'Photography Beginners' Forum' started by nightangel73, Dec 12, 2009.
  1. nightangel73
    nightangel73 TPF Noob!
    May 9, 2009
    21
    USA
    [​IMG]
    [​IMG]
    Ok guys what can I do with this low light situation? Will I need to buy a speedlight flash for this?
    camera is Olympus Evolt
  2. RancerDS
    RancerDS TPF Noob!
    Nov 5, 2009
    227
    Wagoner, OK
    Tripod and slower shutter speed if you are not going to be using any kind of flash. For most photos of friends/family, you would want to use a flash indoors many times. And you might even find it useful for fill-in shots outside.
    Example:[​IMG]
    [​IMG]
  3. Johnboy2978
    Johnboy2978 No longer a newbie, moving up!
    Oct 21, 2004
    1,797
    30
    Southwest Virginia
    well, you've got the ISO jacked up to about as much as you can w/o losing image quality. The exif states that you were already at 1600. Your aperture was at 5.6 on both so I'm going to guess that's as wide as it will go and maybe you were on a kit lens? Both were at 42mm though, so it seems that you should've had another stop or two to open it up, but only you know the answer to that. You were shooting in aperture priority though, so you may have another couple of stops that you could open up the aperture to let more light in maybe. Your choices for better light is to either get a faster lens like a 50mm prime maybe with a max aperture of 1.8 or better yet 1.4 or to use a nice flash. Looks like your white balance was off in both of these as well.
    Either will allow for a lower ISO which will result in less noise.
  4. keith foster
    keith foster TPF Noob!
    Nov 16, 2009
    508
    10
    Missouri, USA
    Get an external flash. It will give you way more flexibility shooting family indoors. You just have to get more light on to the subjects. You have your settings on the camera as good as you can probably get in these situations.
    This site has been recommended by many, many people here and it is a great place to start learning about lights and lighting.
    http://www.strobist.blogspot.com/
  5. HikinMike
    HikinMike No longer a newbie, moving up!
    Nov 6, 2009
    1,438
    147
    Atwater, CA
    Do a custom White balance too. Both have too much yellow in them. If you shot in RAW, you can adjust that in post. ;)
