please help before my camera blows up
Discussion in 'Digital Discussion & Q&A' started by jimaroo, Aug 26, 2006.
  1. jimaroo
    jimaroo TPF Noob!
    Apr 30, 2006
    47
    santa barbara ca
    i have a nikon d70s, and i was wondering if anybody knows what voltage is to high for before it blows up.
    i was using a strobe lite that connected to my hot shoe( forgot what its called) and im afraid that it mite blow up my camera. i've used it a couple times and it seemed to work fine, but i'm kind of scared.
    can anyone help me. the flash is an excalibur sp-1600 monolight.
    also if it is too powerfull, then i could just use the built in flash on my camera to triger the stobe. but i think it would look bad using that little thing.
    anyway any help wood be... very helpfull:D
  2. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    Here is a site that lists many strobe units and their trigger voltage. I didn't see 'excalibur'...maybe it was actually made by another company...do some research on that one. Or you could measure it yourself with the proper equipment.
    Then, you will have to know the safe trigger voltage limit of your camera. If the unit is within your camera's limit...then you are OK.
  3. Digital Matt
    Jan 30, 2004
    5,346
    66
    Santa Barbara, CA
    The sync voltage of most digital SLRs is 6v. I'm not sure if that's the same for the hot shoe though.
  4. jimaroo
    jimaroo TPF Noob!
    Apr 30, 2006
    47
    santa barbara ca
    thanks big mike. ill look into it a little more.
    i've used the light a couple times, and its work good so far. i better check in on it before i mess it up
    oh thank you too matt, your comment just popped up right before mine
  5. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    The usual was 6v but Canon has beefed that up significantly. The 10D was 6 or 9 volts...but the 20D is 250V. I don't know about Nikon or any other cameras though, sorry.
  6. el_shorty
    el_shorty TPF Noob!
    May 12, 2005
    344
    19
    Gaithersburg, MD
    I read somewhere a while ago that all Nikon cameras are designed for a trigger voltage of between 12.5 and 15 volts, but if you are in doubt about your flash's voltage output, use Wein Safe-Synch adapter.
  7. Philip Weir
    Philip Weir TPF Noob!
    Apr 29, 2006
    506
    Sydney, Australia. The land of peace and sunshine.
    Just wind up the voltage until your camera melts, check voltage, then wind it back a bit and buy a new camera, then report back to us. [only kidding]. I've used many different studio flash units over the years and have never even considered the voltage, and have never ever had a problem.
