Please help with metering!
CThomas817
I usually meter manually but yesterday my photos seemed overexposed (children outdoors at sunset). I work in aperature priority when I use the Nikkor 85mm f/1.4 for the bokeh. Should I be matrix metering with this lens and for my subject?
Hi and welcome to the forum.
When you use aperture priority and f1.4 on a bright sunny day, you will very likely overexpose your shot because the camera can´t compensate shutter speed enough to get the right exposure.
You're at maximum aperture, I presume?
We can't always shoot at maximum aperture.
Can you post an example of the result and please include the EXIF, or list the settings? Thanks.
Show us the photos.
Joe
For people use center-weighted metering.
Don't confuse bokeh with depth of field (DoF) shallow or otherwise.
They are different things.
Bokeh is not adjustable.
DoF is and point of focus distance has more effect on DoF than lens aperture does while lens focal length, background distance and image sensor size also affect the depth of the DoF.
Hi - thank you all for the input. I did not shoot at max aperature - I teetered between 2.8 - 4 depending on how close I was to the subject but I guess I was still too open for the shutter capability. I will post some pics in a few min with the corresponding EXIF. I am working on a D3300 if that helps. I know that bokeh is not adjustable and yes I wanted a shallow DOF for some of the shots. This lens has given me a beautiful bokeh even at smaller aperatures and that's why I stick with it for portraits
The last photo is not overexposed but her facial features are washed out and something is off (aside from being dusk blue). Gamma correction in PS helped me a little bit with the super bright photos but I did not get the facial sharpness I was looking for. I used Auto ISO which is why I think I may have metered poorly.
f/4, 1/125, IS0 125
f/3.2, 1/125, ISO 140
f/2.8, 1/125, ISO 100
f 4.5, 1/125, ISO 560
f 5.6, 1/125, ISO 3200
The first two look over-exposed to me...the trend is very much toward "too bright" on those JPEG images. Do you accidentally have some Exposure Compensation set on the camera? Is the camera set to + exposure value?
Just looking at your exposure settings...I mean,What The Heck!!
These are Daylight shots...and the aperture is super-wide and the speeds are sloooooooow....you seem to have a serious fundamental problem, like gross over-exposure.
And, the thing is: in Manual mode, with AUTO ISO enabled, it is possible to set an exposure that is outside the camera's capabilities, and to wind up grossly over-exposed.
f/4, 1/125, IS0 125
You first noted the photos seemed overexposed. You have the EC (exposure comp) set to +.33 for all of the photos. Sharpness is compromised in some of the photos -- my first reaction would be to consider the 1/125th sec. shutter speed the culprit. Auto ISO shouldn't effect metering but the +.33 EC sure does. If you have raw file originals there shouldn't be a problem and in fact the +.33 EC would likely be a benefit.
Joe
The first two look over-exposed to me...the trend is very much toward "too bright" on those JPEG images. Do you accidentally have Exposure Compenstaion set on the camera?
Looks like we clicked post about the same time. You're instinct as usual is right on. He has a +.33 EC set for all of these.
Joe
Yeah, but + 0.33 is only one-third of a stop....a few weeks ago, I used AUTO ISO in Manual mode with my D610, and moved from indoors to outdoors, and took some shots that were wayyyyyy over-exposed. My exposure settings were way to wide an f/stop and way too slow a speed, and I went to the beach...my shots were "yellow-white-over-exposed"...as in realllly wayyy over.
I often ADD 0.3 or 0.7 EV to the metering when shooting RAW with my Nikons...so...I dunno.... +0.3 ought not to cause such horribly bright images.
On a D3400 or whatever, +0.33 EV is nothing...not even an issue...these are wayyyyy screwed up exposures...
If you are shooting in Aperture priority, why are all of the shutter speeds 1/125. That seems almost impossible to occur unless it was done intentionally by adjusting ISO. I don't think there is a problem with the camera metering. It looks more like a problem with how you are setting up the camera. I would have set the Aperture where you wanted it, set the ISO at 100 and let the shutter speed go as high as the camera wanted.
Thank you all for your feedback, I am clearly a beginner and advice is much appreciated. I checked the camera settings and yes exposure comp was set to .3. I did not realize. I should have set it in the opposite direction considering how bright it was.
Dunfly - I am not sure why all of the shutter speeds were 1/125. I was definitely in A mode so both the ISO and shutter speed were automatic.
Next time I will use center-weighted metering and play with the exposure comp or try shooting in manual mode so I can manipulate more.
