PLEASE HELP!!!
Discussion in 'Digital Discussion & Q&A' started by bace, Aug 21, 2006.
  1. bace
    bace TPF Noob!
    Aug 10, 2005
    3,941
    72
    So I started using this "Duotone" feature to make my black and whites look better, only now I can't "save as" anything but a PSD or whatever. Can't save as a jpg. Anyone explain how to do it. Possible explain why I can't do it now?
    Maybe even explain why duotone actually makes my B+W's look better? Am I even using the process properly?
    Thanks!!
    Paul
  2. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    Is your color mode set to RGB?
  3. bace
    bace TPF Noob!
    Aug 10, 2005
    3,941
    72
    no it's set to duotone.
  4. TommiP
    TommiP TPF Noob!
    Jul 29, 2006
    122
    Shrewsbury, UK
    Have you flattened image after modification so you can save as Jpg?
  5. bace
    bace TPF Noob!
    Aug 10, 2005
    3,941
    72
    There is no layers to flatten.
  6. Arch
    Arch Damn You! Staff Member Supporting Member
    Jan 21, 2006
    8,487
    102
    locked in the attic
    i think you have to convert the image to greyscale mode first...... then you can save in whatever format...... off the top of my head i think once you've changed it to greyscale.. you can then change it back to RGB.
  7. bace
    bace TPF Noob!
    Aug 10, 2005
    3,941
    72
    Here's the process that I used.
    a) Convert to Grayscale
    b) Selected Duotone (it's only available once you've converted to grayscale)
    c) Picked two 'tones'.
    d) tried to save as jpg.
    it only lets me save as a psd.
  8. Arch
    Jan 21, 2006
    8,487
    102
    locked in the attic
    yea, so you have to go back to RGB..... It should let you convert it back..... if it doesn't, change it to greyscale again first.... then RGB. ;)
  9. ksmattfish
    Aug 25, 2003
    7,019
    35
    Lawrence, KS
    d) change mode to RGB
    e) save as jpg
  10. bace
    bace TPF Noob!
    Aug 10, 2005
    3,941
    72
    Safe.
    Thanks you lot!!!
