Please recommend a camera
Discussion in 'Collector's Corner' started by Steph, Dec 8, 2008.
  1. Steph
    Steph No longer a newbie, moving up!
    Oct 18, 2006
    1,314
    Steventon, Oxfordshire, UK
    I am looking for a box camera (Kodak Brownie type) with the following features:
    - Very simple lens
    - Camera that uses 120 film
    - Camera that takes square pictures (6x6 cm or 2.25x2.25 in)
    - Non-collectible (I want to use it and it has to be cheap)
    Any suggestion?
    Edit: oh yes! Although I don't want a collectible camera, I put this thread in the collector's corner as people hanging around here are more likely to have suggestions.
  2. viridari
    viridari TPF Noob!
    Dec 4, 2008
    86
    Raleigh
    Maybe a Kiev 88?
  3. PatrickHMS
    PatrickHMS TPF Noob!
    Oct 29, 2008
    1,411
    Metro Atlanta
    You could get a real Kodak Brownie (why get that "type" if that is what you want?) for anywhere from $5.00 - $15.00 on eBay
  4. Steph
    Oct 18, 2006
    1,314
    Far too sophisticated.:wink: I want a back to basics camera to take a pictures like it was done it the 30s and before.
  5. Steph
    Oct 18, 2006
    1,314
    I would, but I cannot find a Brownie that shoots square images on 120 film (do they exist at all?). I have a Brownie that shoots 2.25 x 3.25 in negs (on 120 film) but I cannot find a lab that would actually print that size of negs (most labs only print from 6x4.5, 6x6 and 6x7 negs). Moreover I would prefer square pictures.
  6. bhop
    bhop No longer a newbie, moving up!
    Dec 10, 2007
    2,224
    253
    Los Angeles
    Brownie Hawkeye Flash shoots square images.. that's what I got from my grandma. I'm still working on the first roll though. It's about as simple as it gets. Align image in viewfinder, press the shutter... no adjustments or anything. Tons on ebay, starting at 99¢.
    Only thing about them, they were designed for 620 film, but that's the same size film as 120, just a smaller diameter spool. You just need to use a 620 spool on the take-up side. The 120 spool will work fine on the feed side. Just make sure you either switch the film back to the 120 spool before you send the film out for processing (in total darkness) or request your 620 spool back. Or if you're processing it yourself, make sure you don't toss it since 120 spools won't fit on the take-up end.
  7. Mitica100
    Mitica100 Moderator Staff Member Supporting Member
    Nov 11, 2003
    9,778
    50
    Ahwatukee, AZ
    ^ Good suggestion!
    Also:
    • Kodak Duaflex (although it's a TLR) 6x6 on 620 film
    • ADOX 66 (hard to find though)
    • Anscoflex (TLR)
    • Argoflex (TLR)
    • Spartus 120 Flash
    • Tower Snappy
    That's all I can think of.
  8. Steph
    Oct 18, 2006
    1,314
    Thanks. I will look into those. I wanted to avoid the hassle of re-spooling and that is why I specified 120 film as opposed to 620. This might an option though if I cannot find anything else.
  9. Steph
    Oct 18, 2006
    1,314
    Thanks for your suggestions. I am off to Google and eBay to see what they look like.
  10. Battou
    Battou No longer a newbie, moving up!
    May 10, 2007
    7,997
    26
    Slapamonkey, New York
    There is also the Zeiss Ikon box tengor 54/2, granted yeah it is a collectable and might be a bit tough to locate but it is all metal and can take a beating so useing it properly won't hurt it. I bought one for 6USD at a local antiques dealer. After a quick check there are some available on e-bay currently, one I saw was at ten bucks.
    *EDIT*
    If you are curious
  11. Steph
    Oct 18, 2006
    1,314
    Beautiful camera but I would prefer 6x6 negs. The Tengor shoots 6x9 negs.
  12. IanG
    IanG No longer a newbie, moving up!
    Dec 19, 2007
    239
    39
    Turkey or West Midlnads UK
    What about an Ensign Ful-Vue, easy to find, even in Steventon :D
    Or the Ful-Vue Super, although I've not seen one of those except in adverts. The basic Ful-Vue's were very common in the UK, I can remember our neighbours daughter using one.
    Ian
