Plexi glass??
Discussion in 'Photography Beginners' Forum' started by stang96mj, Jan 4, 2010.
  1. stang96mj
    stang96mj TPF Noob!
    Aug 3, 2009
    69
    Texas
    Does anyone use this in their photos? I have seen a photo with the subjects image reflecting in it and I was told it was plexi glass. Any advice or imput?? Thanks
  2. ann
    ann No longer a newbie, moving up!
    May 14, 2007
    4,263
    189
    i tried it a few times, but don't like it; one barely has to look at it and it scatches.
  3. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    It can also be helpful to protect a seamless paper backdrop, especially if you have to lay it over carpet...but as mentioned, it scratches pretty easily so you don't get a lot of use out of a sheet.
  4. KmH
    Apr 9, 2009
    40,553
    5,544
    Iowa
    Many portrait photographers who use a white background for 'high key', use tile board instead of plexiglass.
    Tile board is less expensive and not quite as reflective as plexiglass. Since tile board is white rather than clear it doesn't show scratches as readily as plexiglass does.
    Tile board has fake tile on one side but the back is white. You get tile board at a home supply or hardware store.
    Obviously, if you're using a colored background plexiglass is your only option.
  5. Dwig
    Dwig TPF Noob!
    Mar 11, 2009
    1,261
    Key West FL
    More often than not the preferred version of tile board is the type used for "dry erase white boards" that doesn't have the fake tile with grout lines look.
    This can work well when used with large subjects at a distance. Tile board has a slight texture and doesn't reflect as clear and sharp a mirror image as the much, much smoother acrylic (e.g. Plexiglass (tm),a cast acrylic, and others like Acrylite (tm) ) and polycarbonite (e.g. Lexan (tm) ) sheets do. If you are doing table top work or portraits with the reflecting surface close to the subject tile board is rarely yields a satisfactory reflection.
