Plug and play storage
Discussion in 'Photography Equipment & Products' started by DjBeau, Jan 1, 2008.
  1. DjBeau
    DjBeau TPF Noob!
    Aug 13, 2007
    50
    Hi
    I'm looking to buy an external hard drive that can be plugged into my camera when I'm travelling - when shooting RAW a memory card won't get you very far.
    I've been Googling it but all I can find is some storage drives with screens. I don't want that! It's not robust enough - I want it simple: just a hard drive, nothing fancy.
    Does this actually exist? Is there a hard drive that can be plugged into the camera and just copy all images from the memory card or MUST there be a menu and therefore a screen on the device to do so? And if there must does any of you know of a good, robust one?
    Best regards
    Bo
  2. Ls3D
    Ls3D TPF Noob!
    Dec 15, 2007
    1,279
    Encinitas Cali
    There are CF drives out there, and they are supported by some manufacturers. Personally I would get a stack of 2 or 4 gig cards - or if money is not a problem slide a 16 gig card in there and shoot em up.
    Of course since I do not know what camera or card type you are using this is a shot in the dark.
    -Shea
  3. DjBeau
    DjBeau TPF Noob!
    Aug 13, 2007
    50
    Oh, forgot to write that I'm shooting on Nikon D80 with SD cards.
    Buying a lot of cards? Nah, it's too expensive in my country and I would prefer a hard drive.
    So still looking for guidance if anyone can give some advice :wink:
  4. usayit
    usayit No longer a newbie, moving up!
    Nov 15, 2003
    9,523
    345
    North New Jersey, United States of America
    Why do you think a screen means the storage (they are called image tanks) are not robust enough? There are two types... first type (the more expensive) has an screen to preview the images stored. Second type has a LCD screen just to show status.
    A hard drive that plugs into your camera does not exist. What does exist is an image tank... which is essentially a hard drive with a built in card reader. You plug in a card and push a button and it copies the contents of the card to the internal hard disk. These will also have a display showing the status of the image tank.
  5. usayit
    Nov 15, 2003
    9,523
    345
    BTW..
    Hard disks have internal moving parts
    SD cards do not... they are solid state memory.
    solid state memory is generally more robust... even though I find SD cards themselves a bit fragile.
    I have two image tanks. Epson P2000 and Wolverine 40GB. The Wolverine is inexpensive with just a status LCD screen. It works although I'm not 100% happy with it. The Epson P2000 keeps me happier but in general the Epson Image tanks (I think they are up to the P5000 now) are expensive.
    the biggest issue I have with image tanks in general is battery power.
  6. DjBeau
    DjBeau TPF Noob!
    Aug 13, 2007
    50
    Why do I expect a screen equals fragility? Well, actually I don't know. I guess it's because I'm oldfashioned in the way that I want things to be simple - for example I hate that all mobile phones have cameras and mp3 player and so on. More things stuffed into an electronic device = more things that can break.
    But I guess a screen is needed to see the status. I'm gonna look for an image tank then (is that the actual sommon term for the device?).
    Thanks! :wink:
  7. Ls3D
    Ls3D TPF Noob!
    Dec 15, 2007
    1,279
    Encinitas Cali
    FYI - Maybe not an SD version, but a CF HDD would fit in MY camera. Moving parts, slower access, its not gunna happen.
    -S
  8. AUZambo
    AUZambo TPF Noob!
    Jan 14, 2007
    573
    6
    Birmingham, AL, USA
    I was in a similar situation when i went to Italy. I didn't want to buy tons of CF cards, nor did I want to have to take my computer to dump pictures on.
    I bought a little 80 GB hard drive that is batter powered (or AC adapter) that I could plug my CF card into to dump pictures. It took about 2 mintues to dump the 4 GB card filled with RAW pictures. Worked like a charm and was easy to carry around.
    Unfortunately, I haven't used it in 6 months and have forgotten who made it or where I got it! When I get home I'll try to find it and give you a link.
  9. Deano
    Deano TPF Noob!
    Jan 1, 2008
    21
    Manchester, UK
    Archos do a great range of hard drives I have a 60GB drive and use it weekly to download from my Canon camera. You can create folders etc and then just plug into your laptop or desktop to back up.
  10. usayit
    Nov 15, 2003
    9,523
    345
    I don't believe the OP was referring to CF type II Microdrives (often marketed under IBM name brand). The microdrives were designed as a lower cost alternative to solid state compact flash media cards during a time when 4GB would have cost you 400-500 bucks. They are increasingly loosing popularity because of there slower performance, less robustness (moving parts, and solid state memory getting cheaper.
    The OP mentioned an "external" hard disk which doesn't fall under the Microdrives criteria.
    Again... you have three choices. 1) more memory cards 2) image tanks 3) Laptop.
    #1 being the most convenient. #3 being the least convenient but "cheapest capacity". #2 being a happy middle.
  11. DjBeau
    DjBeau TPF Noob!
    Aug 13, 2007
    50
  12. Silverbackmp
    Silverbackmp TPF Noob!
    Dec 13, 2007
    89
    I picked up a Zen Data Pool for my recent trip to China. It's made by LG. You buy the case and then purchase a laptop hard drive seperately. It has 2 very small LCD screens for the menus but no big viewing screen. Runs on internal battery or AC (220 or 110). Accepts CF, SD, and several others.
