pn 11 extension tube
Discussion in 'Photography Equipment & Products' started by emogirl, Apr 29, 2007.
  1. emogirl
    emogirl TPF Noob!
    Nov 22, 2006
    622
    Lindsay, Ontario
    I posted this in the landscape forum too...no one had an answer...hope someone here will.
    I found a good deal on a pn 11 extension tube..only $100 in mint condition and I would like to get into some macro work. I'll be using d80 and 50mm 1.4, and a 70-300zoom with it. What kind of magnification would i expect? I understand there is no metering with it or is there spot metering? Is it worth the investment?
    thanks!
  2. Mike_E
    Jan 26, 2007
    5,327
    266
    Hi Emogirl, that sounds way over priced to me! I picked up a set of 3 for -if I remember correctly- $11 + shipping on ebay.
    I don't know off hand what magnification you'd get but I can make a 1" spider about 4" on a 4"X6" print using a 70-210 zoom with an N90s.
    For about $125 S&H you can get an automatic set of 3 from Kenko which will auto-everything I think. http://cgi.ebay.com/Kenko-Auto-Macr...1QQihZ010QQcategoryZ30059QQrdZ1QQcmdZViewItem
    Or if you don't mind manual focus and exposure you can get a set for $19 S&H
    http://cgi.ebay.com/Macro-Extension...1QQihZ006QQcategoryZ79000QQrdZ1QQcmdZViewItem
    I have the manual set (11mm, 18mm, 36mm) and use a push pull zoom for ease of focus (changing focal length changes the focus point too) because I tend to use mine hand held and having 2 ways to focus is nice.
    mike
  3. emogirl
    emogirl TPF Noob!
    Nov 22, 2006
    622
    Lindsay, Ontario
    Thanks guys...the nikon one sells for well over $200 cdn, new...it has tripod collar for easy switch to vertical shots, plus its a much stronger build than the kenkos but no auto exposure... certainly a plus with the kenko set of 3....
    thanks
