Pocket Wizard Plus II
Discussion in 'Beyond the Basics' started by Chris H., Feb 25, 2008.
  1. Chris H.
    Chris H. TPF Noob!
    Jan 10, 2008
    12
    Harrisburg, PA
    Hi,
    Can you use the pocket wizard plus IIs with a nikon sb800? And if so what flash to receiver chord do I need? I dont see any cables listed for nikon on the pocket wizard website.
    Thanks!
    Chris
  2. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    PC Sync chord. IIRC
  3. JerryPH
    Oct 14, 2007
    6,111
    15
    Montreal, QC, Canada
    Yes, and if you use a PW it comes with the right cord already.
    Butif you have a Nikon, especially like something like a D200 or D300... you can trigger the SB-800 via the camera's onboard built-in flash all wirelessly.
    You can choose to use CLS or full manual. You can set flash strength via a D200/300's onboard menu or manually at the strobe.
    Lots of options!
  4. Chris H.
    Chris H. TPF Noob!
    Jan 10, 2008
    12
    Harrisburg, PA
    yea I was reading about using it with a D series camera that sounds really nice! Im using a D80 though so I guess I will have to get a sync cord and use the pocket wizards
  5. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
  6. Chris H.
    Chris H. TPF Noob!
    Jan 10, 2008
    12
    Harrisburg, PA
    What type of triggers would you recommend?
    Thanks!
    Chris
  7. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    Depends on your budget and your expectations. As mentioned, you can get cheap triggers for $20-$40. They are not all that reliable but they do work.
    If you want very reliable triggering, then PWs are the way to go.
    If you want TTL metering, then stick with Nikon wireless setup.
  8. Chris H.
    Chris H. TPF Noob!
    Jan 10, 2008
    12
    Harrisburg, PA
    The main thing I am looking for I feel is range..
    Thanks for the help everyone!
    Chris
  9. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    Well, Pocket Wizards probably have the best range. I think they are rated for 1600 feet or more.
  10. Jus7 A Phas3
    Jus7 A Phas3 TPF Noob!
    Sep 26, 2007
    236
    CA
    PW's or skyports, skyports are cheaper but not as good but overall still good.
