polarizers??
Discussion in 'Beyond the Basics' started by pelooyen, Jul 9, 2003.
  1. pelooyen
    pelooyen TPF Noob!
    Jul 9, 2003
    I have a Minolta 404si and recently bought a linear polarizer. I then discovered that since my camera is AF Program, I would probably need a circular polarizer instead. I understand that using a linear one would result in underexposure. Can I continue to use the linear one and overexpose the shot? If so, does anyone know how many f-stops to overexpose? (trying to save money.)
    On another note, if I need to buy a cicular polarizer, is there any difference between brands. There seems to some range available
    thanks in advance
  2. dlc
    dlc TPF Noob!
    May 14, 2003
    293
    Indianapolis IN
    Yes, you need circular with AF lenses. I have used Tiffen for years with the results I needed. They are good as cost/performance ratio is concerned, but there are maybe a little better as Hoya, B+W. Just get a multi-coated rather than plain. The prices go up as the filter gets larger.
  3. voodoocat
    voodoocat ))<>(( Supporting Member
    May 15, 2003
    5,277
    17
    Gilbert, AZ
    I don't think linear polarizers cause the film to be underexposed, they make it hard for the AF to focus.
