Polarizing filters....
Discussion in 'Photography Equipment & Products' started by JeffieLove, Mar 17, 2010.
  1. JeffieLove
    JeffieLove No longer a newbie, moving up!
    Feb 8, 2010
    1,605
    15
    Elkton, MD
    I know the main things that are recommended with the polarizing filters is to have multi-coated circular...
    Well, I searched on adorama for the size I need, with circular and polarizing in the keywords for the search and this list came up...
    58mm polarizing circular multi-coated - Adorama.com
    There is glass, wide angle, plastic, thin, 16-layer, super hard, etc...
    I've never heard any of those things mentioned when people are recommending polarizing filters...
    Can someone help me out?
  2. Garball
    Garball TPF Noob!
    Mar 17, 2010
    16
    Denver
    Don't stress - buy a used tiffen circular coated 37.00 and you're good to go.
  3. JeffieLove
    Feb 8, 2010
    1,605
    15
    Elkton, MD
    where did you see one for $37? I feel a bit retarded now lol...
  4. JeffieLove
    Feb 8, 2010
    1,605
    15
    Elkton, MD
    This is the one I added to my cart... It's $70... Does that sound about right?
    And if I get this to fit my two 52mm lenses, all I need to make it fit my 58mm lens is a 52-58mm step up ring, right?
    Hoya 52mm Circular Polarizer Multi Coated Glass Filter
  5. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    Don't do it that way.
    When you put a smaller filter on a larger lens (with a step down ring), you are likely to get vignetting (darkening of the edges) because the filter will block the lens.
    Instead, get the filter to fit your largest lens and use step down rings for your smaller lenses.
  6. JeffieLove
    Feb 8, 2010
    1,605
    15
    Elkton, MD
    got it...
    so now i have the 58mm polarizing filter and a 58-52mm step down ring ;)
    thanks Mike :)
  7. Montana
    Montana TPF Noob!
    May 27, 2008
    1,533
    Eastern Montana
    you can, but then your hoods wont fit with the ring and filter attached.
  8. JeffieLove
    Feb 8, 2010
    1,605
    15
    Elkton, MD
    I have 58 and 52mm hoods. They should fit either way right.
  9. ann
    ann No longer a newbie, moving up!
    May 14, 2007
    4,263
    189
    using a hood with a polarizing filter is tricky as you have to rotate the ring to make the necessary correction. Of course this can be over come, but not when shooting on the run. At least not for me:(
  10. Overread
    May 1, 2008
    24,079
    4,175
    UK - England
    Honestly if you want to use hoods with circular polarizers there are two approaches.
    1) Cut a hole in your hood so that you can reach the polarizer to turn it
    2) Go on ebay and get a screwthread fit hood - one that screws into the filter thread rather than over the outside. Then you can use the hood and have access to turn the filter.
  11. ann
    May 14, 2007
    4,263
    189
    option two certainly makes a lot of sense and that is the direction i will be moving, cutting a hole in the hood is not an option i would undertake.
  12. JeffieLove
    Feb 8, 2010
    1,605
    15
    Elkton, MD
    My 52mm hood is a screwhead. The 58mm is not. I will look into replacin that.
are vivitar camera filters any good
vivitar cpl filter review
vivitar polarizing filter
vivitar series 1 polarizer review
