Portrait lens recommendations for Nikon D5200
Discussion in 'Nikon Accessories' started by Lanna.O, Feb 15, 2016.
  1. Lanna.O
    Lanna.O TPF Noob!
    Dec 19, 2015
    16
    Hi. I have nikon d5200 with 18-55mm lens and i want to buy some equipment for professional photography. I'm looking forward to buy 50mm, 35mm and 85mm lenses. 85mm lens is a bit expensive so I'm looking for an alternative, cheaper version of it. Need some advices about it.
    Thanks :1247:
  2. jcdeboever
    jcdeboever TPF Supporters Supporting Member
    Sep 5, 2015
    14,360
    7,801
    Michigan
    whats your budget?
  3. Lanna.O
    Lanna.O TPF Noob!
    Dec 19, 2015
    16
    400$
  4. jcdeboever
    Sep 5, 2015
    14,360
    7,801
    Michigan
    That can get you a used Nikon 85mm 1.8G which is a fantastic lens but you will have to look around, people tend to keep them. Keep in mind that it would work on a FX camera if you ever decide to upgrade.
    If you don't mind manual focus, the 85mm 1.8 AF-D can be had for around $300.
    Nikon Nikkor 85mm f/1.8D AF Telephoto Lens | KEH Camera
    Here is a 2 Kit lens promo 35mm & 85mm that has been going on for a while. It has the Nikon 85mm 3.5G but still a very sharp lens, just not as fast as the 1.8G but it has macro and VR function. These are both limited to DX camera's but still an excellent value.
    Nikon Macro & Portrait Lens Kit
    For $76 more dollars, you can get new
    Nikon 85mm F/1.8
    • Like Like x 1
  5. Lanna.O
    Lanna.O TPF Noob!
    Dec 19, 2015
    16
    Thank you!
  6. jcdeboever
    Sep 5, 2015
    14,360
    7,801
    Michigan
    • Like Like x 1
  7. jaomul
    jaomul Been spending a lot of time on here!
    Feb 4, 2011
    5,544
    1,470
    Cork Ireland
    I'd skip the 85mm until you get a 50 first. The 85mm is long on your body for portraits and can be restrictive unless you have lots of room to step baaaaaccckkkkkk.....
    • Like Like x 1
  8. Designer
    Designer Been spending a lot of time on here!
    Apr 13, 2012
    16,384
    4,107
    Iowa
    Oh, ha-ha, I asked some questions in your other thread.
    I have both a 50 and an 85, and although I love them both, I would much prefer the focal length of the 85 over the 50 and certainly over the 35mm for portraiture. The reason being, (assuming one has the physical space to use the longer lens) longer lenses render portraits better in that the distortion is minimized. Shorter lenses are for when you've run out of space in which to back up more.
  9. astroNikon
    astroNikon 'ya all Bananas I tell 'ya Supporting Member
    Aug 15, 2013
    13,359
    3,241
    SE Michigan
    • Like Like x 1
  10. Lanna.O
    Lanna.O TPF Noob!
    Dec 19, 2015
    16
    Thanks for answers! It was helpful :1247:
  11. Lanna.O
    Lanna.O TPF Noob!
    Dec 19, 2015
    16
    So is the 50mm best portrait lens which can i get for my camera?
  12. Designer
    Apr 13, 2012
    16,384
    4,107
    Iowa
    As I attempted to explain; longer lenses are more flattering in portraiture, but if you're cramped for space, then the 50. Or your zoom at 55mm. There's nothing wrong with the 18-55 IMO.
best pourtriet leanse for nikon d5200
nikon d5200 best portrait lense
nikon portrait lens recommendations
