Portraits with small light modifiers
nf1
Toronto, ON, Canada
Website
pixelcam.ca
I've just finished a test of two small portable light modifiers for my blog and wanted to share the images I got. Constructive comments and critiques are welcome.
Portable-Octabox-30cm-Portrait-1.jpg Portable-Octabox-30cm-Portrait-2.jpg Portable-Softbox-20x30cm-Portrait-1.jpg Portable-Softbox-20x30-Portrait-2.jpg
The modifiers used are quite small and portable:
The first two images are with 30 cm (12") Octabox.
The second two are with 30x20 cm Softbox.
Great for creating drama but horrible for creating a faltering image unless you do a proper retouch. Cross lighting with a harsh light is only going to exaggerate skin texture and imperfections. You need some serious dB on image 1. Image 3 and 4 don't do anything for me with 4 looking like on camera Flash. I often use contrasty lighting via square reflectors or grided dishes however I know when doing this the makeup has to be on point and the retouching must be strong. Also this kind of lighting should relate with the styling hair and makeup along with model expression and posture. Soft possing doesn't work.
Sent from my SM-N920C using Tapatalk
View attachment 115226 View attachment 115227 View attachment 115228 View attachment 115229
I am not sure what you are trying to do. Make good portraits or just do something quick and easy? These are quite poor. If you want good examples of portraits, look here:
hurrell - Google Search
Be sure to look only at the ones by Hurrell!
“The most essential thing about my style was working with shadows to design the face instead of flooding it with light” George Hurrell.
http://in1.ccio.co/O3/o/pC/32394e0602c6d50b06a779d94aac29eb.jpg
Thanks for the feedback but please take into consideration that for these I got to use only small light modifiers (20-30cm in size) not my 60" umbrella or softbox. The lack of post processing is intentional as I wanted to demonstrate to quality of the light. Perhaps I could've done some on the skin though. @FKP007 fully agree that such small lights are good for drama or backlight, thanks for the tip on stronger and more dramatic expression as well - I completely forgot about that and I shouldn't have. What do you mean by "serious dB"? Sorry not familiar with the abbreviation.
If you do have suggestions regarding how to better utilise such reflectors (light setup, framing or else - I'm all up for it :), but please don't suggest swapping the reflectors for larger ones.
Dodge and burn...for retouching.
Small light sources are great however like mentioned try and get the posing expression and styling to work also with the quality of light. Here is an example where i used a square reflector and grid.
Excellent, although I prefer the main light from the viewer's left.
http://www.filmnoirblonde.com/wp-content/uploads/2015/08/Joan-Crawford-shot-by-George-Hurrell.jpg
Makes no difference really.
Thanks for the example, it is great! Can you share what is the light modifier used for this? Did you used a reflector or backlight left and behind of the model?
Traditional it maybe but like I said it makes no difference really. In reality the key should be set according the subjects face (best side) largest eye, features etc.
It looks weird the other way.
That's weird you think that...some amazing fashion, beauty and traditional portraits out there that have the key camera right...don't think it makes the work look weird.
You learn something new every day! Today's the day. Remember, I know everything!
https://c2.staticflickr.com/4/3206/2735437502_8feff559c3.jpg
Top-left lighting - Wikipedia, the free encyclopedia
What is Rembrandt lighting, and when do I use It?
You can send me all the links you want my friend..I know lighting and art very well...I teach them both. But you should know that with any type of art there are different ways alternatives and interpretations. Doesn't make any more or less valid...especially when you're talking about which direction the key light comes from. Don't be so stiff, you are allowed to light from a different side you know lol
"There are notable exceptions to this convention, such as Sandro Botticelli's The Birth of Venus."
And many many others I might add.
