post poduction thought...
Discussion in 'Photographic Discussions' started by gravity0, May 8, 2009.
  1. gravity0
    gravity0 TPF Noob!
    Mar 18, 2009
    107
    Dallas
    I know that pictures are post processed to make models look better. Blemishes dissapear. I've seen before and after shots of some models that I couldn't believe. From old an d busted to new Hotness. How much goes into post production when singing? In all seriousness. I mean there has to be touch up to everyone in the cut room right? No-one is perfect.
  2. bigboi3
    bigboi3 TPF Noob!
    Apr 1, 2009
    599
    6
    Pittsburg, CA
    for singing I don't think there is... but I know for a fact that if they make a mistake they can just start a couple measures where they did the mistake and so on and so forth.
  3. Torus34
    Torus34 No longer a newbie, moving up!
    Jan 26, 2006
    2,117
    37
    Tottenville, Staten Island, NYC USA
    The gentle art of retouching is almost as old as photography.
    And, while we're at it, do you think the painters of oil portraits paint precisely what they see?
    Or that the Egyptian statues of the Pharaohs are completely accurate depictions?
    Then there's the realm of autobiographies.
    'Nuff said.
  4. craig
    craig TPF Noob!
    Oct 30, 2003
    5,600
    21
    Hermosa Beach, CA U.S.A
    Not sure what you are trying to say here. I can say that photography and art is about creating your own personal vision. Wether that means straight from film or 4 hours in Photoshop and Illustrator it is up to YOU. There is no right or wrong.
    Love & Bass
  5. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    As much as needed. I have seen people with perfect skin where touchups would just be a case of a few colour and contrast tweaks. Then I've seen other "models" with crowsfeet under the eyes already. They will take significantly longer to bring to magazine quality.
  6. Dwig
    Dwig TPF Noob!
    Mar 11, 2009
    1,261
    Key West FL
    There is a lot of post processing done in audio recordings. Small noises (lip smacks, breaths, ...) are removed tonal balance (the audio equivalent of color balance) is adjusted, echos reduced or created. Some of this is done in post and some is done "live" with inline audio processors. Also, its been standard for nearly a half century to use multi-track recording techniques where each performer is recorded on a separate track even though they perform together in the same studio. The balance between the tracks (8, 16, 32, ...) can be experimented with while mixing down to a stereo pair, both the relative volumes and the stereo placement can be changed and edits and effects can be diffferent on each track.
  7. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Oh you are talking about audio?
    Well let me tell you on a high end hifi you can hear pitch adjustment working on many modern albums, mostly voices often get in my opinion destroyed by much of what goes on in the mastering studio these days.
  8. skieur
    skieur TPF Noob!
    May 14, 2007
    5,076
    202
    Canada
    There is a lot of audio editing and mixing that goes on with singing. That is why some singers sound better on cd than live and why some lip sync as opposed to live singing takes place at some concerts.
    skieur
  9. Mike_E
    Jan 26, 2007
    5,327
    265
    Scads. If it weren't for producers now days, there would be few stars at all.
    I call as witness American Idol where stars are made yearly.
  10. pplsearch
    pplsearch TPF Noob!
    May 27, 2009
    Southern California
    I think there is a lot of touch-up work that has become standard nowadays. If you walk down the grocery aisle where they store all the women's magazines, you'll see so many covers with models that you can tell were touched up. It's even to the point where it doesn't look as real. Not that it's good or bad, just that that's the industry (of image).
  11. rufus5150
    rufus5150 TPF Noob!
    Mar 8, 2008
    1,658
    Austin, Texas
    For mainstream music, some require a lot, some require very little at all. Today's tools can correct pitch, move entrances around, shrink or lengthen phrases. Many tools in use can correct these in line rather than in post.
    But just like images, even the perfect 'out of camera' images ('studio live' is what we called them... often one of our vocalists would insist on doing the entire song that way), you touch it up in ways you couldn't or were extraordinarily difficult. You add a bit of reverb in post, maybe some analog delay, post-process compression, perhaps some eq, maybe you split-track it and play with the panning to position the audio. Like photo editing, you've an infinite amount of tools with which to screw things up, but you can also make pretty cool results as well.
    Back (ages ago, we were using 24 track digital, protools and the like were in their infance) when I was cutting a guitar track on a song for a local act, I ended up doing 32 takes. They kept the first take except for the last 2 bars or so.
    Many years later I was doing a bass track for a friend and we were just having a terrible time with one particular entrance. The engineer gave up on us and said 'okay, play the notes', recorded them completely out of context and moved them into place.
    I've also worked with vocalists who will (need to have the engineer) piece together entire lines from different phrases.
  12. adamwilliamking
    adamwilliamking TPF Noob!
    Feb 24, 2009
    481
    Top 40 producers or any producer trying to emplify a top 40 producer puts a crazy amount of post process into everything. You won't hear a song recorded in the last 5 years (pop.) that is not dynamically engineered. The human ear + brain can pick up timing changes that we wouldn't recognize during the listening experience but will greatly effect the overall listening experience. For this reason many (I want to say ALL serious producers) artifically warp the timing of a full session to recreate something that would be technically impossible live off the floor. Many other things but I would also disagree with the above poster about only "some" new artists using an autotune. Everything you hear on the radio has been autotuned, the extremities obviously change from Coldplay to T-Pain but rest assured that no producer is taking the chance of even a millisecond of pitch slip up to appear in the song.
