post processing help
Discussion in 'Photography Beginners' Forum' started by Xavi, Feb 20, 2010.
  1. Xavi
    Xavi TPF Noob!
    Jul 22, 2009
    125
    Corona
    Hello everyone! I was hoping to get some post processing help on this picture I took earlier today of some of my classmates. I made the mistake of shooting directly into the sun and unfortunately overexposed the background. I've been trying to mess with it for about an hour now but I can't seem to blue up the sky in subtle natural way. Everything I've tried just ends up looking tacky... Perhaps some of you PP gurus will have some better luck with it. I'd like to keep the color version but if its impossible to fix I was thinking of just leaving it black and white to mask the blown out sky. Any help is greatly appreciated!
    F/7.1 Exp 1/160sec ISO 100 Ap Mode.
    best regards
    Javier
    Here is the picture in color:
    [​IMG]
    and the same one I made B&W and cropped a bit
    [​IMG]
  2. frommrstomommy
    frommrstomommy Been spending a lot of time on here!
    Feb 3, 2010
    2,320
    979
    florida
    for the original in color I feel like its a lost cause.. or definitely beyond my abilities to correct. I don't see how what has been washed out can be brought "back to life" without HOURS of work - and even then I just can't see it.
    I did mess with your black and white one though, and to be honest I think I prefer the black and white either way.
    [​IMG]
  3. creisinger
    creisinger TPF Noob!
    Oct 19, 2009
    470
    Miami
    Stick with the sepia/bw one.
    The color version is trashed - the over exposed parts of the sky don't contain any color information anymore, there is simply nothing to restore.
    Inserting a sky from another image into this one won't work well either as the trees in the background are also blown out.
    If someone was to replace the sky properly he/she would have to remove everything from the shoulders upwards in order to remotely get realistic borders between foreground and sky.
    When you have lighting conditions like these you need to find an area where you have more diffused light - in this situation maybe in the shade of the tree.
    Sepia turned out pretty good actually. Like it.
  4. frommrstomommy
    Feb 3, 2010
    2,320
    979
    florida
    Oh, I should probably explain what I did in case you like it.. lol
    in CS2 - levels, curves and some sharpening.
  5. sA x sKy
    sA x sKy TPF Noob!
    Feb 15, 2009
    80
    Long Island, NY
    [​IMG]
    5 minutes of work. I tried to make it as subtle as possible.
  6. creisinger
    Oct 19, 2009
    470
    Miami
    Well done!
  7. Proteus617
    Proteus617 TPF Noob!
    Jun 3, 2007
    410
    35
    I cropped and converted to greyscale just to make things easy, but you could do the same in color. Created a correction layer (copy of the original), then a mask. Used an edgefider on the mask, erased the people and painted in everything else. Then blurred the mask so there are no hard edges between areas with different contrast. Once that's done, you can adjust the subjects and background individually. You could go further and create another layer mask for the sky. Just to illustrate (it could be much more neatly done)...original cropped and converted to greyscale:
    [​IMG]
    With the correction mask, only background affected. the weird halos are from me being sloppy with the brush:
    [​IMG]
  8. frommrstomommy
    Feb 3, 2010
    2,320
    979
    florida
    Mind sharing what you did in short? I couldn't make a thing happen, not quickly anyhow..
  9. sA x sKy
    sA x sKy TPF Noob!
    Feb 15, 2009
    80
    Long Island, NY
    Sure, why not. I used a plugin from Nik Software called Color Efex which has all these options to enhance color in an image. Respectively, Silver Efex Pro is the plugin which allows to convert to and enhances shade or "black and white" of an image.
    For this image, I used the "Neutral Density Grad" filter in Color Efex and adjusted the settings to make it look realistic enough.
  10. Xavi
    Xavi TPF Noob!
    Jul 22, 2009
    125
    Corona
    frommrstomommy and Proteus617 thank you so much for the B&W renditions and the explanations you provided. They both look great in my eyes. Now I can't seem to decide between the color or B&W because I like them both now. Thank you both for your time.
    Creisinger: Thank you for your input as well. i really thought the color version was hopeless too until I saw sA X Sky's version. I really like what the other members did with the black and white version though so I'm keeping that one too. Thanks again
    sA X sky: Wow that looks great. Im so glad the color version was salvaged with the post work you did. Thank you for your time and explanation. I'm still learning how to post process pictures and the help the community provided will really help my work mature. Thanks again
    Javier
  11. Layspeed
    Layspeed TPF Noob!
    Oct 11, 2009
    307
    British Columbia, California & Philippines
    Javier, great photo. Perhaps ask your classmates which one they prefer and give them what they want. Some might like the color, where others prefer the B&W. But least you have options now. :thumbup: Unless you weren't planning on giving them a copy, nevermind. :lol:
  12. lvcrtrs
    lvcrtrs TPF Noob!
    Dec 18, 2008
    606
    Pennsylvania
    I like the OP B&W effort.
