PP with LR problem
Discussion in 'Beyond the Basics' started by Jon0807, Sep 7, 2009.
  1. Jon0807
    Jon0807 TPF Noob!
    Nov 16, 2007
    357
    4
    San Francisco, CA
    I've recently been using LR to do PP work and I love it for the most part. I was using Canon's DPP software but found it fairly limited. My only problem with LR is that I've noticed that in my landscape photos there seems to be a banding in the sky that never used to happen with DPP. I've only noticed it when I work with LR. Is there something I'm doing wrong with regards to any of the conversion from RAW to JPG? Or is there something else I'm doing wrong. Here's a sample of what I'm talking about. Hopefully the bands show up clearly.
    Edited with DPP (and PS for border and name)
    [​IMG]
    And this edited with LR
    [​IMG]
    I can clearly see a circular banding in the sky in the LR photo that's not showing in the DPP photo.
    Thanks in advance and any advice is greatly appreciated.
  2. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    What's the lightroom one look like completely un-edited? The saturation in the Lightroom image is very high, especially the blues.
    Branding occurs in all software once you exceed the bounds of what the image data is capable of, or if you do dodgy conversions between different colour profiles and bitrates.
  3. Jon0807
    Jon0807 TPF Noob!
    Nov 16, 2007
    357
    4
    San Francisco, CA
    Here's the photo completely unedited. Straight conversion from RAW to JPG using LR.
    [​IMG]
    I can still almost see the banding on the left side of the photo. But I was playing with the saturation and vibrance and they both seem to accentuate the bands no matter how little or a lot I apply, even when I completely desaturate. I normally shoot in complete neutral settings in RAW so saturation adjustment is one of the things I always do. In DPP I boosted the saturation quite a bit as well.
    And just for comparison here's the unedited version converted from DPP
    [​IMG]
    I've just noticed that the two pics are different even tho I haven't done anything to either one of them. I'll have to check my the export settings on LR...
  4. GeneralBenson
    GeneralBenson TPF Noob!
    Mar 28, 2008
    1,106
    18
    Boulder, CO
    Joshua Tree
    Are you converting to jpg, then importing to LR and editing, or importing RAWs to LR, editing and then exporting as jpg? What does the original look like? The first one looks like cranking some serious color out of a RAW that wasn't there, the second one looks like cranking some serious color out of a jpeg that wasn't there.
  5. GeneralBenson
    Mar 28, 2008
    1,106
    18
    Boulder, CO
    What are your export settings? You should see banding like that when you export and unedited RAW. What qulity jpeg are you exporting?
  6. Jon0807
    Jon0807 TPF Noob!
    Nov 16, 2007
    357
    4
    San Francisco, CA
    Unless LR is doing something I'm not aware of, I thought I was importing to LR directly from RAW and working with RAW in DPP as well then converting to JPG.
  7. Jon0807
    Jon0807 TPF Noob!
    Nov 16, 2007
    357
    4
    San Francisco, CA
    Both are exported with high quality to JPG. It's just confusing me why it's happening with LR and not DPP when I'm basically doing the same types of editing.
  8. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Hmm the Lightroom defaults are far more saturated and contrastier than the DPP defaults. That's interesting, in the case of Nikon Capture it's the other way around.
    You have me stumped...
  9. andrew99
    andrew99 TPF Noob!
    Jan 23, 2008
    672
    Toronto, Canada
    I don't have LR, I use Photoshop and Adobe Camera RAW... But when you're saving the JPEG from LR, are you using the best quality setting? What colour space are you using (sRGB?). And does the image have the banding visible in LR before you save it?
  10. Jon0807
    Jon0807 TPF Noob!
    Nov 16, 2007
    357
    4
    San Francisco, CA
    I export at the highest settings and in sRGB and I can see the banding when I import so something is happening when I import into LR. I've been searching through the settings to see if there's anything I can find but nothing. I'll keep searching
  11. davebmck
    davebmck TPF Noob!
    Mar 10, 2008
    678
    Waxhaw, NC
    What camera profile are you using? You might try another profile to see if that changes your results.
  12. Jon0807
    Jon0807 TPF Noob!
    Nov 16, 2007
    357
    4
    San Francisco, CA
    I keep my camera on neutral and I always shoot in RAW. That way I can do all adjustments in PP. I've played around with LR quite a bit with a few photos that have the banding and nothing I can do makes it go away. It's something having to do with the way LR is importing the images and I don't see where I can change those settings. Guess I'll just have to switch to DPP when I notice banding in LR
