Practice Make perfect ?
Discussion in 'Photography Beginners' Forum' started by jewely, Aug 24, 2010.
  1. jewely
    jewely TPF Noob!
    Aug 20, 2010
    83
    Utah
  2. jewely
    jewely TPF Noob!
    Aug 20, 2010
    83
    Utah
    also i know theese are no where perfect at all... also there is no editing to theese
  3. tirediron
    Jul 8, 2005
    40,649
    12,306
    Victoria, BC
    Good start, and #1 is a good use of the bridge as a leading line.
  4. LCARSx32
    LCARSx32 TPF Noob!
    Jun 8, 2010
    641
    Cedar Hill, Missouri, USA
    Good shots for your first time in manual mode. Here's some thoughts I had:
    #1 - The sky is waaaaay over exposed. Honestly, I don't know how you would fix it because a faster shutter would have under exposed the bridge. You would probably have to use some off camera lighting to get this shot to work. Also, I'm not a huge fan of the composition. I think it's because I want to see more of the bridge itself rather than just the railing. I dunno...
    #2 - I like the composition better, but the super shallow depth of field doesn't work for me. Try a larger f/#. You shot at f/4 (I'm guessing that's wide open on your lens?). The smaller the f/# the shallower the depth of field (the area that's in focus.) I would try f/8 or f/11 to widen it a bit so the twig sticking through the railing would be in sharp focus as well. Your sky is blown out again in this shot, but I think it works.
    #3 - As far as I see, this shot is technically good (proper exposure, good focus). But I'm not a fan of the subject. It just doesn't make me look very long. I understand this is your first time, but an interesting subject goes a long way.
    #4 - Not a very interesting shot, unfortunately. The flash definitely doesn't help. If possible, try to avoid the built in flash. There's only a few rare instances that they help a photo. A speedlight with a swivel/tilting head only costs about $30-40 and the difference is night and day; especially if you get a diffuser for it.
    It's a good first attempt at manual mode. I would suggest googling the "exposure triangle" as well as how aperture affects depth of field (DOF). That will help you a lot, I think. You might read up on composing pictures, too. You do pretty well, but there's good information to be had.
  5. jewely
    jewely TPF Noob!
    Aug 20, 2010
    83
    Utah
    TY so much also i understand why you dont like the subject ,, however they are my boys bikes so i geuss that makes the difference to me ,, not that your wrong it is kinda boring to someone else but again my babies :)
  6. jewely
    jewely TPF Noob!
    Aug 20, 2010
    83
    Utah
    bump :D
