Pre-Wet?
Discussion in 'The Darkroom' started by Bobby Ironsights, Nov 11, 2007.
  1. Bobby Ironsights
    Bobby Ironsights TPF Noob!
    Dec 3, 2006
    331
    12
    Thunder Bay, ON, Canada
    Does anyone here pre wet their film?
    It's par for the course with sheet film, but I wonder about doing it on my roll film.
    How/Would it affect developing times?
    Bobby.
  2. Flash Harry
    Flash Harry No longer a newbie, moving up!
    Jun 26, 2006
    1,965
    14
    Durham, UK
    I've never pre-wet any film, sheet or otherwise, who told you this, its a fallacy. H
  3. Chris of Arabia
    Chris of Arabia Herding cats since 1988... Supporting Member
    Mar 10, 2007
    7,825
    16
    The Magic Kingdom
    It's a while since I processed anything, but I never found the need. Then again, with the first 30 seconds spent inverting and tapping like Fred Astaire, there wasn't a snowball's chance in hell a bubble was going to settle anywhere on the film itself. As to wetting in advance, I can't think of any reason why dev time should be affected - so long as you've tipped all of the wetting liquid out.
  4. JC1220
    JC1220 TPF Noob!
    Sep 13, 2005
    439
    Maine
    There is nothing wrong with doing pre-wetting or pre-washing of your film, although most modern films don't require it, always check the manufactures suggestions.
    Even so, some good reasons to do: it greatly reduces the likelyhood of air bubbles forming on the film, promotes even development and brings your film to the same temp as your developer. The most important of these is the even development, especially if you are using short development times.
    Development time, contrast or both may be affected depending on the film as the pre-wet will slow and dilute the initial developer contact.
  5. Alpha
    Alpha Troll Extraordinaire
    Mar 15, 2005
    5,454
    41
    San Francisco
    I never do it currently for sheet because I'm developing stuff shot at ISO 12, so my developer concentration is so low (HC-110, 1:100) that it's not realy going to affect development consistency. I'll pre-wet the faster stuff though.
  6. JC1220
    JC1220 TPF Noob!
    Sep 13, 2005
    439
    Maine
    ISO 12? niffty, what film?
  7. Jeff Canes
    Jeff Canes No longer a newbie, moving up!
    May 19, 2003
    6,192
    22
    Hollywood, FLA USA
    I do a pre-wash, not sure if it helps any, with Kodak or Ilford don’t recall much of change in the water color, but for Rollei and Efke (classis Adox emulsion) there is a change in the water color
  8. Alpha
    Mar 15, 2005
    5,454
    41
    San Francisco
    Kodak Contrast (Process Ortho). Absolutely zero grain. It is so unbelievably sharp.
  9. pete1606
    pete1606 TPF Noob!
    Dec 16, 2007
    78
    NYC
    For 35mm film, it is not nessicary to pre soak your film in water. For large or medium format film it is nessicary. It softens the emulsion and ensures even application of the developer. You should see all the water when it comes our of my tank purple. It does make a difference for medium format.
