Preventing lens from fogging up
Discussion in 'Photography Beginners' Forum' started by Darkhunter139, Feb 11, 2010.
  1. Darkhunter139
    Darkhunter139 TPF Noob!
    Nov 27, 2009
    773
    Valley Forge, PA
    We have about 2 feet of snow on the ground outside right now and I want to go take some pictures. Problem is last time I took my camera out in the cold weather the lens fogged up when I brought it back in. Is that bad for the camera?
    Does this happen to anyone else and is there anything I can do to prevent this from happening? I dont really mind if its not going to hurt anything though.
  2. Dao
    Dao No longer a newbie, moving up!
    Mar 24, 2008
    6,252
    418
    St. Louis
    Someone here suggested in the past that use a Ziplock bag and put the camera (or lens) inside the bag before entering the other environment. And let the temperature of the equipment rise to the room temperature before taking them out.
  3. Darkhunter139
    Nov 27, 2009
    773
    Valley Forge, PA
    Cool thanks I will give that a try.
  4. bgaideski
    bgaideski TPF Noob!
    Feb 7, 2010
    59
    Ann Arbor, MI
    Yes, that can be very very bad. If condensation ends up inside the lens you could ruin it.
    Here is what I find works. When going outside keep your camera in your camera bag. stand out there for a few minutes and let the bag get more to outside temperature. Then bring your camera out, do your shooting. When you are done put the camera back in your bag. Then bring the bag inside. Do not open your camera bag until It becomes more of a room temperature. Then when you take your camera out it will still be cold, but it wont be so extremely cold, and the lens probably wont fog.
  5. Big Mike
    Dec 16, 2003
    33,876
    1,826
    Edmonton
    That is condensation...and it can form on all the cold surfaces of your gear...inside and out....so yes, it can be harmful.
    To prevent condensation, you need to isolate your cold gear from warm/humid air. As mentioned, you can seal it up in plastic etc. and allow it to warm up before taking it out.
    At the very least, leave the gear zipped up in your camera bag while it warms up. It's probably not air tight, but it's better than nothing.
    I also keep little bags of desiccant (silica gel) in my camera bag, to absorb some moisture.
  6. Darkhunter139
    Nov 27, 2009
    773
    Valley Forge, PA
    The zip lock bag worked great thanks :)
  7. TiaS
    TiaS TPF Noob!
    Jan 23, 2010
    116
    Newfoundland
    I have this problem. So you put the camera in the ziplock while outside? How long does one have to leave it sit in the bag in the house? I find that my camera takes an awful long time for the condensation to leave the lens in winter.
  8. Darkhunter139
    Nov 27, 2009
    773
    Valley Forge, PA
    I left it in there for like an hour. Probably could have taken it out sooner if I wanted. I put it in the bag right before i came in
  9. Josh66
    Oct 31, 2007
    14,604
    1,238
    Cedar Hill, Texas
    Yes. After you're done shooting, of course.
    Till it gets back up to room temperature.
  10. Mulewings~
    Mulewings~ TPF Noob!
    Dec 28, 2009
    433
    SW Wisconsin
    Yup...works perfect that way.
camera lens fogging prevent
how to keep camera lens from fogging
how to keep lens from fogging up in cold
how to keep your camera lens from fogging
how to prevent camera lens fogging up
how to prevent camera lens fogging up during night photography
keep your camera from fogging up in cold weather
prevent lens from fogging up
prevent security camera from fogging up when cold
prevent vision camera fogging
