Price differences in filters
Discussion in 'Photography Equipment & Products' started by deadtoaster2, Apr 29, 2007.
  1. deadtoaster2
    deadtoaster2 TPF Noob!
    Apr 22, 2007
    31
  2. Alpha
    Alpha Troll Extraordinaire
    Mar 15, 2005
    5,454
    41
    San Francisco
    Filters start getting expensive very fast once you break 60mm. It's important to remember that even with something like a polarizer, with its very specific purpose, you want to minimize the glass between lens and subject. If something has to be in between, it had better be good. With that said, when it comes to your basics like UV and colored filters, it doesn't make that much of a difference. It probably does a bit more when you start talking ND and PL's. If I had a choice, I would stick to the big makers, like Hoya and Tiffen, or anything with a major name on it like Canon, Nikon, Leica, etc.
  3. xfloggingkylex
    xfloggingkylex TPF Noob!
    May 5, 2006
    1,292
    Frederick, MD
    most people here agree that for the most part, you get what you pay for when it comes to filters, with diminishing returns. when I bought a circular polarizer, I bought a multi coated Hoya.
  4. panocho
    panocho TPF Noob!
    Feb 7, 2005
    425
    Compostela, GZ
    the same kind of difference as between lenses, I guess. After all, it's just a matter of glass.
    If you use cheaper lenses, why not filters as well; a good filter won't make a bad lens good. Now if you have spent money on a good lens, don't make it a bad one by adding one "element" of considerably worse glass
  5. fmw
    fmw No longer a newbie, moving up!
    Sep 30, 2006
    3,656
    471
    Yes. $100+ dollars.
  6. RMThompson
    RMThompson the TPF moderators rock my world!
    Nov 12, 2006
    1,888
    11
    Also there are TWO types of polarizing filters, linear and circular.... there is a HUGE difference between the two when it comes to photography.
    Linear doesn't play nice with the modern Autofocus and metering that rely on split-beam technology, which the modern TTL cameras use. The cicular filters DO however, so that's ONE reason they are more expensive.
    Circular filters should only work in ONE direction whereas a linear one can be seen through both sides!
    Here is an article on the web I found about it, that explains the more technical side:
