Print head dirty each time
Discussion in 'Photography Equipment & Products' started by 250Gimp, Jan 15, 2009.
  1. 250Gimp
    250Gimp TPF Noob!
    Oct 3, 2006
    1,031
    Chelsea, Quebec
    I have an Epson R800 printer and I don't use it regularly. I am quite choosey about what photos I print so teh printer will sometimes sit for a month or more between print sessions.
    The trouble I am having is that each time I use the rpinter it seems I have to run the head cleaning utility, which uses quite a bit of ink.
    Is there anything I can do between uses to prevent having to clean the head each time?
    (And yes, I know I could always just print more :er: )
  2. Phelan
    Phelan TPF Noob!
    Dec 30, 2008
    116
    NW Arkansas
    Inkjet printers when not used for extended periods end up with ink dried around the nozzles on the print heads (plus dust) which is what it is cleaning off. Other than using it more regularly there's not much you can do.
  3. I share your pain, 250Gimp.
  4. Mike_E
    Jan 26, 2007
    5,327
    266
    Do you leave it on all the time? I've heard that just turning them off will help.
    Couldn't hurt. ;)
  5. 250Gimp
    250Gimp TPF Noob!
    Oct 3, 2006
    1,031
    Chelsea, Quebec
    Thanks for the response Phelan.
    Thanks for the sympathy Iron Flatline!
    Mike E, I do not have it on unless I am going to use it.
    No magic bullet I guess!!
    Cheers
  6. Joves
    Joves No longer a newbie, moving up!
    Dec 14, 2007
    2,399
    21
    Flagstaff/Az
    Nope there are no magic bullets. I keep mine covered but, it still doesnt keep the ink from dying on the heads. I hate wasting ink like that too.
  7. nmerrick
    nmerrick TPF Noob!
    Jan 13, 2009
    50
    Oakland, TN, USA
    I, too, share your pain - I've had an Epson 4000 for about 4 years now and it's always been a pain in the butt with nozzles clogging constantly.
    Sometimes, it takes as many as 15 cleaning cycles to clean it! :x
    Hope you get yours sorted out.
    Nigel
  8. Laurence
    Laurence TPF Noob!
    Mar 5, 2008
    87
    I also owned an Epson printer, and had the problem of constantly having to clean the printhead. I went through ink and $$$ very rapidly.
    I now own an HP 8550, and it has a removable/replaceable print head. Though somewhat high in cost, the print head replacement is certainly less than a bunch of ink that is used just to clean the printhead...and also is better on my "anger scale" against the darn dried out printhead on the Epson.
    I go a long time between prints with the HP, but so far no clogs at all. Print quality is exactly comparable to the Epson 2200.
  9. Phelan
    Phelan TPF Noob!
    Dec 30, 2008
    116
    NW Arkansas
    A trick used a lot in the old days on inkjets for cleaning the heads was rubbing alcohol soaked q-tips rubbed over the heads.
  10. 250Gimp
    250Gimp TPF Noob!
    Oct 3, 2006
    1,031
    Chelsea, Quebec
    hhhmmm I'll have to try the alcohol thing!!!.....oh wait......was that to drink or use on the printer??? ;)
    seriously though, I will try the rubbing alcohol next time.
    So far it only takes one, maybe two cleaning cycles to get it printing well.
    Cheers
  11. Phelan
    Phelan TPF Noob!
    Dec 30, 2008
    116
    NW Arkansas
    Rubbing alcohol for the printer, some nice rum or vodka for you. :)
