print size for digital
Discussion in 'Beyond the Basics' started by JohnMF, May 18, 2005.
  1. JohnMF
    JohnMF TPF Noob!
    Mar 25, 2005
    3,009
    11
    UK
    What is the biggest size you can print an 8.2 megapixel at without it losing quality?
    thanks
  2. ksmattfish
    Aug 25, 2003
    7,019
    35
    Lawrence, KS
    That depends on the opinion of the photog or viewer. I like to stick to 300 dpi, which means somewhere around 8"x12". That's as large as I like go with 35mm too. I'm picky.
  3. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    There are lots of other factors that contribute to the quality of enlarged photographs. Try searching the forums, this has been discussed a few times before.
  4. Digital Matt
    Jan 30, 2004
    5,346
    66
    Santa Barbara, CA
    You lose quality as soon as you print it :p It will never look as good as it does on screen. I've printed 6.3mp photos at 20"x30" and I find them acceptable from a short distance.
  5. etaf
    etaf TPF Noob!
    May 19, 2005
    98
    Surrey, UK
    300PPI is the normal guide - i have seen pictures on walls printed as low as 180PPI
    so take the pixels in the photo and divide by the PPI
    so if the pixels are
    3000 x 300 @ 300PPI that will print {3000/300 by 300/300} 10" x 1"
    3000 x 300 @ 30PPI that will print {3000/30 by 300/30} 100" x 10"
    however, 30 pixels per inch will look awful - like the dots on a newspaper print - more dots better the picture
    hope that helps
  6. JohnMF
    JohnMF TPF Noob!
    Mar 25, 2005
    3,009
    11
    UK
    thanks for the help
  7. SLOShooter
    SLOShooter TPF Noob!
    Dec 21, 2004
    421
    Luckily the bigger it the farther back people can stand from it which givers you a little leeway in the DPI. Look around and you'll find some answers.
  8. jp_w
    jp_w TPF Noob!
    May 18, 2005
    Bremerton, WA
    Just thought I'd add that I've printed upto 16x20 with my D70 (6 megapixel) and they've turned out fantastic. Even at a very close distance.
  9. Artemis
    Artemis Just Punked Himself
    May 16, 2004
    5,313
    43
    England! w000t!
    Well, 6.3 megapixels on my Canon 300D is said to be able to print A3 (same size as what Jp_w put?) so...bigger than A3....A2? id say about A2.
  10. Jeff Canes
    Jeff Canes No longer a newbie, moving up!
    May 19, 2003
    6,192
    22
    Hollywood, FLA USA
    I’ve also have had 6mp jpg images printed up to 20x30 inch by on-line services with very nice results. Mostly have used kodakgallery.com (Ofotos) in the pass. Just placed an order for a 20x30 with Mpix.com for the first time today. Expect it to be fine.
    It’s all has to do with the software that the printer uses to print.
  11. Ravenscroft
    Ravenscroft TPF Noob!
    May 12, 2005
    38
    Bonnyville, Alberta
    the manual for my fujifilm S5100 (4.0 megapixel) says I can print up to 8x10 with little to no loss of quality when using the best quality of jpeg format that the camera has. i imagine that with raw format i could go higher. but i have yet to test the theory so take it at face value.
  12. JohnMF
    JohnMF TPF Noob!
    Mar 25, 2005
    3,009
    11
    UK
    A3 or A2 would be great.
    I suppose i'll just have to get a few done to see.
    thanks people
