Print Size
Discussion in 'Beyond the Basics' started by Dmitri, Jan 16, 2010.
  1. Dmitri
    Dmitri No longer a newbie, moving up!
    Jun 20, 2008
    5,879
    39
    End of the line
    Keep in mind I am not smart.
    What is the formula/math/etc. to find out the maximum print size of a photo?
    For example, say a photo is 1000 pixels by 1000 pixels, 300 resolution - how do I find out the maximum print size that it will still look good and not go bad?
    Do I go by what photoshop tells me is the image size (for example, if it says 10 inches by 10 inches when I go to resize)?
    Thanks in advance.
  2. rufus5150
    rufus5150 TPF Noob!
    Mar 8, 2008
    1,658
    Austin, Texas
    Number of pixels per side/resolution.
    so 1000 pixels/300 is 3.33, so 3.33 inches on each side for your example. Photoshop usually does the math correctly, though. :)
  3. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Look good is variable that depends on viewing distance. Viewing distance is variable and depends on print size. It's a very strange way that leads to non-exact figures for "looks good".
    300ppi resolution for instance is a standard print resolution specified mostly for 6x4 and 8x5 prints which are typically viewed at arms lengthish. If you print a 40" wide image then you won't need to print at 300ppi because to actually look at the image properly will require you to step back. Double the distance back and you half the resolution you need.
    On top of this all of these numbers assume perfect vision. Nanna will assume your 100ppi images are absolutely gorgeous :)
  4. davebmck
    davebmck TPF Noob!
    Mar 10, 2008
    678
    Waxhaw, NC
    I have made prints at 16x20 at 140ppi that are perfectly sharp, even up close. You might be able to get away 100ppi on that size image as long as you don't resample to get to that resolution. At 100ppi your 1000x1000 pixel image could print at 10x10 inches.
  5. davebmck
    davebmck TPF Noob!
    Mar 10, 2008
    678
    Waxhaw, NC
    Nanna??
  6. Dwig
    Dwig TPF Noob!
    Mar 11, 2009
    1,261
    Key West FL
    You haven't provided enough information to calculate. There is absolutely no possible way to answer without also specifying the viewing distance.
    The common wisdom (reasonably accurate but not precise) is that for a print made on a premium printer and to be viewed at normal reading distance needs to be in the range of 300 pixels per inch (that's actual ppi on the print and NOT necessarily the ppi setting spec'd in the digital file).
    In fact, very few people will detect a difference between 240ppi and 300ppi and almost no one will notice the difference between 150ppi and 300ppi unless they are comparing prints side by side, especially when the print is large. When the viewing distance is longer, lower original resolutions are fine though when an image drops below 150ppi it is generally best to upsample it at least 150 before printing if you have good image processing software.
  7. KmH
    Apr 9, 2009
    40,742
    5,588
    Iowa
    That statement, is a self fullfilling prophecy. ;)
    It's likely you're quite a bit smarter than you're giving yourself credit for.
  8. HikinMike
    HikinMike No longer a newbie, moving up!
    Nov 6, 2009
    1,438
    147
    Atwater, CA
    Grandmother. ;)
  9. RyanLilly
    RyanLilly No longer a newbie, moving up!
    Aug 27, 2007
    1,478
    8
    St. Louis, Missouri, USofA
    For practical application, take Mpix for example. Their printers output at 250ppi and the recommended minimum is 100ppi. The resolution setting on your file will not effect the print size, it only changes how the image is displayed on your screen. For printing only the total number of pixels and viewing distance will determine how large the print can be.
    Here are Mpix recommendations for file preparation. Mpix.com - Help
    Also, having a properly exposed image, with dead on focus, and without the need to adjust the exposure much in post, will be a significant factor in the size of print that is possible.
  10. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Sigh. Americans. You know I actually ended up leaving a bag at home one day when an American friend asked me where he should put it and I said the "boot of the car". He didn't know what the boot was so just left the bag in my room. :lol: "Oh you meant the trunk" is no consolation for we need need to go back and get it! :lmao:
  11. davebmck
    davebmck TPF Noob!
    Mar 10, 2008
    678
    Waxhaw, NC
    Funny, we called it the "boot" too when I was growing up. I'm from the South though.
  12. HikinMike
    Nov 6, 2009
    1,438
    147
    Atwater, CA
    Actually my nieces call them 'nana' and 'papa'. My kids call them grandma and grandpa.
