Print Sizes
Discussion in 'Photography Beginners' Forum' started by nutsngum, Aug 28, 2007.
  1. nutsngum
    nutsngum TPF Noob!
    Aug 5, 2007
    35
    I'm using a Rebel XTi on the highest jpg quality setting, just wondering - how big can you blow up an actual photo print without it being pixely? I'm assuming it varies depending on the picture but any guidance would be nice. Thanks!
  2. Buszaj
    Buszaj TPF Noob!
    May 23, 2007
    521
    Toronto
    Not exactly sure, but I would think pretty big. I have a 3.1 megapixel and I can blow it up to 8x10 with sharp quality. If you have a sharp image, you could probably make it quite big. You've got 10.1 megapixels!
  3. nutsngum
    nutsngum TPF Noob!
    Aug 5, 2007
    35
    another question about aspect ratios, how does the print change when you print 4x6 up to something like 16x20 or 20x24, does it cut off on the sides?
  4. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    You can easily make large prints like 16x20 or 20x24. There are several factors that will improve the chances of getting a good enlargement...a good lens, for example. Of course, simple things like a fast enough shutter speed or the use of a tripod will help.
    The camera shoots in a 2:3 aspect ratio...which means that a 4x6 print is the perfect ratio. If you print a 5x7, 8x10 16x20 or 20x24 etc...then you will need to do some cropping. I wouldn't recommend leaving this up to the lab...if you are ordering a print, you should crop it to that ratio yourself first.
  5. WDodd
    WDodd TPF Noob!
    Feb 20, 2007
    899
    Amherst (Cleveland), Ohio
    Sometimes you can get larger prints in a 2:3 aspect ratio depending on where you go. I know www.mpix.com does 8x12's
  6. Kaye68
    Kaye68 TPF Noob!
    Aug 28, 2007
    43
    make sure your resolution is set to 300 for prints at least that is what I use
